Datasheet ADT7310 (Analog Devices) - 24
Описание | ±0.5°C Accurate, 16-Bit Digital SPI Temperature Sensor |
Страниц / Страница | 24 / 24 — ADT7310. Data Sheet. OUTLINE DIMENSIONS. 5.00 (0.1968) 4.80 (0.1890). … |
Версия | A |
Формат / Размер файла | PDF / 403 Кб |
Язык документа | английский |
ADT7310. Data Sheet. OUTLINE DIMENSIONS. 5.00 (0.1968) 4.80 (0.1890). 4.00 (0.1574). 6.20 (0.2441). 3.80 (0.1497). 5.80 (0.2284)
link to page 24 link to page 24
ADT7310 Data Sheet OUTLINE DIMENSIONS 5.00 (0.1968) 4.80 (0.1890) 8 5 4.00 (0.1574) 6.20 (0.2441) 1 3.80 (0.1497) 5.80 (0.2284) 4 1.27 (0.0500) 0.50 (0.0196) 45° BSC 1.75 (0.0688) 0.25 (0.0099) 1.35 (0.0532) 0.25 (0.0098) 8° 0.10 (0.0040) 0° COPLANARITY 0.51 (0.0201) 1.27 (0.0500) 0.10 0.31 (0.0122) 0.25 (0.0098) SEATING 0.40 (0.0157) PLANE 0.17 (0.0067) COMPLIANT TO JEDEC STANDARDS MS-012-AA CONTROLLING DIMENSIONS ARE IN MILLIMETERS; INCH DIMENSIONS -A 7 (IN PARENTHESES) ARE ROUNDED-OFF MILLIMETER EQUIVALENTS FOR 0 4 2 REFERENCE ONLY AND ARE NOT APPROPRIATE FOR USE IN DESIGN. 1 0
Figure 25. 8-Lead Standard Small Outline Package [SOIC_N] Narrow Body (R-8) Dimensions shown in millimeters and (inches)
ORDERING GUIDE Model1 Temperature Range Temperature Accuracy2 Package Description Package Option
ADT7310TRZ –55°C to +150°C ±0.5°C 8-Lead SOIC_N R-8 ADT7310TRZ-REEL –55°C to +150°C ±0.5°C 8-Lead SOIC_N R-8 ADT7310TRZ-REEL7 –55°C to +150°C ±0.5°C 8-Lead SOIC_N R-8 EVAL-ADT7X10EBZ Evaluation Board 1 Z = RoHS Compliant Part. 2 Maximum accuracy over the −40°C to +105°C temperature range.
©2009–2011 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. D07789-0-12/11(A)
Rev. A | Page 24 of 24 Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications SPI Timing Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Circuit Information Converter Details Temperature Measurement One-Shot Mode 1 SPS Mode CT and INT Operation in One-Shot Mode Continuous Read Mode Shutdown Fault Queue Temperature Data Format Temperature Conversion Formulas 16-Bit Temperature Data Format 13-Bit Temperature Data Format 10-Bit Temperature Data Format 9-Bit Temperature Data Format Registers Status Register Configuration Register Temperature Value Register ID Register TCRIT Setpoint Register THYST Setpoint Register THIGH Setpoint Register TLOW Setpoint Register Serial Interface SPI Command Byte Writing Data Reading Data Interfacing to DSPs or Microcontrollers Serial Interface Reset INT and CT Outputs Undertemperature and Overtemperature Detection Comparator Mode Interrupt Mode Applications Information Thermal Response Time Supply Decoupling Temperature Monitoring Outline Dimensions Ordering Guide
