Datasheet SRK1001 (STMicroelectronics) - 4
ПроизводительSTMicroelectronics
ОписаниеAdaptive synchronous rectification controller for flyback converter
Страниц / Страница27 / 4 — SRK1001. Maximum ratings. Table 2. Absolute maximum ratings. Symbol. Pin. …
Формат / Размер файлаPDF / 615 Кб
SRK1001. Maximum ratings. Table 2. Absolute maximum ratings. Symbol. Pin. Parameter. Value. Unit. Table 3. Thermal data. DS13155. Rev 1
SRK1001 Maximum ratings Table 2 Absolute maximum ratings Symbol Pin Parameter Value Unit Table 3 Thermal data DS13155 Rev 1
33 предложений от 11 поставщиков
Микросхема: ADAPTIVE SYNCHRONOUS RECTIFICATI
SRK1001TR
от 43 ₽
SRK1001TR
от 123 ₽
SRK1001TR
179 ₽
SRK1001TR
link to page 4 link to page 4
SRK1001 Maximum ratings 2 Maximum ratings Table 2. Absolute maximum ratings Symbol Pin Parameter Value Unit
VCC 4 DC supply voltage -0.3 to 36 V DVS 5 Drain sense voltage referred to GND (with 300 Ω in series to the pin) -3 to 185 V VAUX 6 Auxiliary DC supply voltage -0.3 to 185 V VTOFF 7 TOFF pin voltage rating -0.3 to 3.6 V VTON 8 TON pin voltage rating -0.3 to 3.6 V VSYNC/DIS 1 DIS/SYNC pin voltage rating -0.3 to 3.6 V Stressing the device above the rating listed in above table may cause permanent damage to the device. Exposure to absolute maximum rated conditions may affect device reliability.
Table 3. Thermal data Symbol Parameter Value Unit
Θth j-amb Max. thermal resistance, junction-to-ambient(1) 125 °C/W Ψth j-case Max thermal resistance, junction-to-case top(1) 5 °C/W Ptot Power Dissipation @Tamb = 50°C 0.8 W Tj Junction Temperature Operating range -40 to 150 °C Tstg Storage Temperature -55 to 150 °C 1. Natural convection test environment, using JEDEC 1s1p PCB with vias.
DS13155
Rev 1 page 4/27
Document Outline 1 Block diagram and pin connection 2 Maximum ratings 3 Typical application schematic 4 Electrical characteristics 5 Operation description 5.1 Drain voltage sensing 5.2 Turn-on 5.3 Minimum TON programming 5.4 Adaptive turn-off and TIMER 5.4.1 Fixed frequency mixed DCM/CCM operation 5.4.2 QR operation (with valley skipping) 5.4.3 Fixed frequency DCM operation 5.4.4 Variable frequency CCM operation 5.5 Minimum TOFF programming 5.6 Start-up phase 5.7 Low consumption mode operation: sleep-mode, burst mode, disable state 5.8 DIS/SYNC pin functions 5.9 VAUX pin operation in CC regulation 5.9.1 Example for parameter calculations 5.10 Operation in CC regulation and short circuit 5.11 Adaptive gate drive 6 Layout guidelines 7 Package mechanical data Revision history
