Datasheet IX4351NE (IXYS) - 4
ПроизводительIXYS
Описание9A Low Side SiC MOSFET & IGBT Driver
Страниц / Страница12 / 4 — IX4351NE. 1.3 Absolute Maximum Ratings. Parameter. Symbol. Minimum. …
Формат / Размер файлаPDF / 334 Кб
IX4351NE. 1.3 Absolute Maximum Ratings. Parameter. Symbol. Minimum. Maximum. Units. 1.4 Recommended Operating Conditions
IX4351NE 1.3 Absolute Maximum Ratings Parameter Symbol Minimum Maximum Units 1.4 Recommended Operating Conditions
I
IX4351NE
NTEGRATED CIRCUITS DIVISION
With respect to VCOM unless otherwise specified.
Positive Supply Voltage VDD -0.3 32 V Negative Supply Voltage VSS -10 0 V Supply Voltage Range VDD - VSS -0.3 40 V Gate Drive Output Voltages VOUTSRC , VOUTSNK , VOUTSOFT VSS - 0.3 VDD + 0.3 V Gate Drive Output Current IOUTSRC , IOUTSNK - ±9 A Logic Input Voltage VIN -0.3 7 V DESAT Input Voltage VDESAT -0.3 VDD + 0.3 V SET Input Voltage VSET - 1 7 V FAULT Output Voltage VFAULT -0.3 VDD + 0.3 V VREG Output Voltage VVREG -0.3 7 V Junction Temperature TJ -55 +150 °C Storage Temperature TSTG -55 +150 °C
1.4 Recommended Operating Conditions Parameter Symbol Minimum Maximum Units
Positive Supply Voltage VDD 13 25 V Negative Supply Voltage VSS -10 0 V Input Voltage VIN 0 5.5 V Operating Ambient Temperature TA -40 125 °C
1.5 Electrical Characteristics
(VDD=20V, VSS=-5V, COM=GND=0V, CDD=CREG=4.7F, CSS=10F, TA=-40°C to +125°C, unless otherwise specified.) 1.5.1 VDD Section
Parameter Conditions Symbol Minimum Typical Maximum Units
Operating VDD Supply Current fIN=100kHz, CLOAD=2.2nF IDD - 19 28 mA Quiescent VDD Supply Current No load IDDQ - 2.9 4.4 mA VDD UVLO Rising Threshold - VDDUV+ 10 12 13 V VDD UVLO Hysteresis - VDDHYS - 2 - V 1.5.2 VREG Section
Regulator Output Voltage IVREG=-5mA VVREG 4.2 4.6 5 V Line Regulation 15V < VDD < 25V, IVREG=-5mA  - 0.1 0.2 V VVREG Load Regulation IVREG=-1mA to -10mA - 0.1 0.4 V 4
www.ixysic.com
R02 Document Outline Features Applications Description Ordering Information 1 Specifications 1.1 Package Pinout 1.2 Pin Description 1.3 Absolute Maximum Ratings 1.4 Recommended Operating Conditions 1.5 Electrical Characteristics 1.6 Thermal Characteristics 2 Performance Data 3 Performance Data (Cont.) 4 Functional Description 4.1 Logic Input (IN) 4.2 Gate Drive Outputs (OUTSRC and OUTSNK) 4.3 Internal 4.6V Regulator (VREG) 4.4 Negative VSS Charge Pump Regulator 4.5 Desaturation Detection and Protection 4.6 Thermal Shutdown 4.7 FAULT Output 5 Manufacturing Information 5.1 Moisture Sensitivity 5.2 ESD Sensitivity 5.3 Soldering Profile 5.4 Board Wash 5.5 Mechanical Dimensions
