Datasheet PDS1040 (Diodes) - 2
ПроизводительDiodes
ОписаниеGreen 10A Schottky Barrier Rectifier
Страниц / Страница6 / 2 — PDS1040. Maximum Ratings. Characteristic. Symbol. Value. Unit. Thermal …
Формат / Размер файлаPDF / 401 Кб
PDS1040. Maximum Ratings. Characteristic. Symbol. Value. Unit. Thermal Characteristics. Typ. Max. Electrical Characteristics. Min
PDS1040 Maximum Ratings Characteristic Symbol Value Unit Thermal Characteristics Typ Max Electrical Characteristics Min
34 предложений от 12 поставщиков
Зенер
Россия и страны ТС
PDS1040Q-13
Diodes
от 43 ₽
PDS1040Q-13
Diodes
94 ₽
Эиком
PDS1040Q-13
Diodes
от 100 ₽
PDS1040Q-13
Diodes
(@TA = +25°C, unless otherwise specified.) Single phase, half wave, 60Hz, resistive or inductive load. For capacitance load, derate current by 20%.
Peak Repetitive Reverse Voltage VRRM Working Peak Reverse Voltage VRWM 40 V DC Blocking Voltage VR RMS Reverse Voltage VR(RMS) 28 V Average Rectified Output Current IO 10 A Non-Repetitive Peak Forward Surge Current I 8.3ms Single Half Sine-Wave Superimposed on Rated Load FSM 275 A
Thermal Characteristics Characteristic Symbol Typ Max Unit
Thermal Resistance Junction to Soldering Point RJS  1.5 °C/W Thermal Resistance Junction to Ambient Air (Note 5) RJA 95  °C/W Thermal Resistance Junction to Ambient Air (Note 6) RJA 75  °C/W Thermal Resistance Junction to Ambient Air (Note 7) RJA 50  °C/W Operating Junction Temperature Range VR  80% VRRM -65 to +150 T °C V J R  50% VRRM -65 to +180 Storage Temperature Range TSTG -65 to +150 °C
Characteristic Symbol Min Typ Max Unit Test Condition
Reverse Breakdown Voltage (Note 8) V(BR)R 40   V IR = 1mA  0.45 0.49 IF = 8A, TS = +25°C  0.47 0.51 I Forward Voltage V F = 10A, TS = +25°C F  V  0.41 IF = 8A, TS = +125°C  0.42 0.49 IF = 10A, TS = +125°C  0.02 0.3 TS = +25C, VR = 35V  5.5 25 T Reverse Leakage Current (Note 8) I S = +100C, VR = 35V R  mA 0.03 0.7 TS = +25C, VR = 40V  6.5 50 TS = +100C, VR = 40V Notes: 5. FR-4 PCB, 2oz. Copper, minimum recommended pad layout per http://www.diodes.com. 6. Polyimide PCB, 2oz. Copper, minimum recommended pad layout per http://www.diodes.com. 7. Polyimide PCB, 2oz. Copper. Cathode pad dimensions 9.4mm x 7.2mm. Anode pad dimensions 2.7mm x 1.6mm. 8. Short duration pulse test used to minimize self-heating effect. 9. Polyimide PCB, 2oz. Copper. Cathode pad dimensions 18.8mm x 14.4mm. Anode pad dimensions 5.6mm x 3.0mm. 10. Devices mounted such that RJA = 19°C/W. POWERDI is a registered trademark of Diodes Incorporated. PDS1040 2 of 6 December 2015 Document number: DS30538 Rev. 11 - 2
www.diodes.com
© Diodes Incorporated
