Клеммники KEEN SIDE
Datasheet LT3083 (Analog Devices) - 21
ОписаниеAdjustable 3A Single Resistor Low Dropout Regulator
Страниц / Страница28 / 21 — TYPICAL APPLICATIONS. Low Voltage, High Current Adjustable High …
ВерсияB
TYPICAL APPLICATIONS. Low Voltage, High Current Adjustable High Efficiency Regulator*
TYPICAL APPLICATIONS Low Voltage, High Current Adjustable High Efficiency Regulator*
41 предложений от 20 поставщиков
Интегральные микросхемы Силовые чипы — регуляторы напряжения — линейные
LT3083EQ#PBF-ES
406 ₽
LT3083EQ#TRPBF
LT3083EQ#PBF
LT3083EQ
LT3083
100k PGOOD SVIN INTVCC 1µF 1Ω 2Ω CMDSH-3 4.7µF BOOST 8V PVIN 0.22µF 1µH 10k 10µF 274k SW 150µF x3 100µF LTC3610 IN LT3083 ×4 150µF ION 2N3906 1µF VCONTROL VFB 60.4k RUN/SS 10mΩ 0.1µF 10k OUT SET V V RNG ON 10nF 10k FCB IN LT3083 VCONTROL EXTVCC ITH 1.5k SGND PGND 470pF 10nF 10mΩ 0V to 4V 10A (MAXIMUM) OUT SET 4mA MINIMUM LOAD IN LT3083 VCONTROL * DIFFERENTIAL VOLTAGE ON LT3083 IS 0.6V SET BY THE VBE OF THE 2N3906 PNP = WURTH 74437349010 10mΩ OUT SET IN LT3083 VCONTROL 10mΩ SET OUT 3083 TA13 20k 100µF Rev. B For more information www.analog.com 21 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Pin Functions Block Diagram Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
