Datasheet LM334S (Analog Devices) - 3
ОписаниеConstant Current Source and Temperature Sensor
Страниц / Страница12 / 3 — ELECTRICAL CHARACTERISTICS. CURRENT SOURCE (Note 2). LM134. LM334. …
Формат / Размер файлаPDF / 165 Кб
ELECTRICAL CHARACTERISTICS. CURRENT SOURCE (Note 2). LM134. LM334. SYMBOL. PARAMETER. CONDITIONS. MIN. TYP. MAX. UNITS
ELECTRICAL CHARACTERISTICS CURRENT SOURCE (Note 2) LM134 LM334 SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
53 предложений от 27 поставщиков
Стабилизатор тока, программируемый выход от 1мкА до 1мА, 40В питание, 400мВт, TO-92-3
727GS
LM334Z
от 423 ₽
LM334Z
LM334Z#TRPBF
ТаймЧипс
LM334Z/NSC
LM134 Series
ELECTRICAL CHARACTERISTICS CURRENT SOURCE (Note 2) LM134 LM334 SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
∆ISET Set Current Error, V+ = 2.5V 10µA ≤ ISET ≤ 1mA 3 6 % (Note 3) 1mA < ISET ≤ 5mA 5 8 % 2µA ≤ ISET < 10µA 8 12 % Ratio of Set Current to 10µA ≤ ISET ≤ 1mA 14 18 23 14 18 26 V– Current 1mA ≤ ISET ≤ 5mA 14 14 2µA ≤ ISET ≤ 10µA 18 23 18 26 VMIN Minimum Operating Voltage 2µA ≤ ISET ≤ 100µA 0.8 0.8 V 100µA < ISET ≤ 1mA 0.9 0.9 V 1mA < ISET ≤ 5mA 1.0 1.0 V ∆ISET Average Change in Set Current 1.5V ≤ V+ ≤ 5V 0.02 0.05 0.02 0.1 %/V ∆VIN with Input Voltage 2µA ≤ ISET ≤ 1mA 5V ≤ V+ ≤ VMAX (Note 5) 0.01 0.03 0.01 0.05 %/V 1.5V ≤ V ≤ 5V 0.03 0.03 %/V 1mA < ISET ≤ 5mA 5V ≤ V ≤ VMAX (Note 5) 0.02 0.02 %/V Temperature Dependence of 25µA ≤ ISET ≤ 1mA 0.96 1.04 0.96 1.04 Set Current (Note 4) CS Effective Shunt Capacitance 15 15 pF
TEMPERATURE SENSOR (Note 2) LM134-3,LM234-3 LM134-6, LM234-6 SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
∆ISET Set Current Error, V+ = 2.5V 100µA ≤ ISET ≤ 1mA ±1 ±2 % (Note 3) Tj = 25°C Equivalent Temperature Error ±3 ±6 °C Ratio of Set Current to 100µA ≤ ISET ≤ 1mA 14 18 26 14 18 26 V– Current VMIN Minimum Operating Voltage 100µA ≤ ISET ≤ 1mA 0.9 0.9 V ∆ISET Average Change in Set Current 1.5V ≤ V+ ≤ 5V 0.02 0.05 0.02 0.1 %/V ∆VIN with Input Voltage 100µA ≤ ISET ≤ 1mA 5V ≤ V+ ≤ 30V 0.01 0.03 0.01 0.05 %/V Temperature Dependence of 100µA ≤ ISET ≤ 1mA 0.98 1.02 0.97 1.03 Set Current (Note 4) Equivalent Slope Error ±2 ±3 % CS Effective Shunt Capacitance 15 15 pF
Note 1:
Absolute Maximum Ratings are those values beyond which the life is expressed as a percent deviation from this amount. ISET increases at of a device may be impaired. 0.336%/°C at Tj = 25°C.
Note 2:
Unless otherwise specified, tests are performed at Tj = 25°C with
Note 4:
ISET is nominally directly proportional to absolute temperature pulse testing so that junction temperature does not change during test. (°K). ISET at any temperature can be calculated from: ISET = IO (T/TO)
Note 3:
Set current is the current flowing into the V+ pin. It is determined where IO is ISET measured at TO (°K). by the following formula: ISET = 67.7mV/RSET (at 25°C). Set current error
Note 5:
VMAX = 40V for LM134 and 30V for other grades. 3
