Datasheet TPD7106F (Toshiba) - 7
ПроизводительToshiba
ОписаниеIntelligent Power Device Silicon Power MOS Integrated Circuit
Страниц / Страница22 / 7 — TPD7106F. 7.4. Truth Table (protect function and diagnosis output). Table …
Формат / Размер файлаPDF / 637 Кб
TPD7106F. 7.4. Truth Table (protect function and diagnosis output). Table 7.5 Truth table (2). Charge pump. OUT1. OUT2. DIAG
TPD7106F 7.4 Truth Table (protect function and diagnosis output) Table 7.5 Truth table (2) Charge pump OUT1 OUT2 DIAG
TPD7106F 7.4. Truth Table (protect function and diagnosis output) Table 7.5 Truth table (2) Charge pump OUT1 OUT2 DIAG Rapd off IN1 IN2 STBY Boost drive VCPV M1 Note3 M2 Note3 M3 Note3 M6 Note3 operation
H X X L V = CPV L stop Disable Hiz OFF OFF Hiz OFF OFF (pull up) L L H V ≦ CPV VCPL Operation Disable L OFF ON Hiz OFF L ON H L Disable H ON OFF Hiz OFF L HNote1 Enable L OFF ON L ON HNote2 Disable L OFF ON Hiz OFF H HNote1 Enable L OFF ON L ON HNote2 Disable L OFF ON Hiz OFF L L V > CPV VCPL Disable L OFF ON Hiz OFF H OFF H L Disable H ON OFF Hiz OFF (pull up) L HNote1 Enable L OFF ON L ON HNote2 Disable L OFF ON Hiz OFF H HNote1 Enable L OFF ON L ON HNote2 Disable L OFF ON Hiz OFF Note1: Rapid off drive operation time (100μs typ.) Note2: After Rapid off drive. Note3: Refer to the following figure of the device name. VDD CPV M1 OUT1 DIAG OUT2 M6 M2 M3 M5 M4 GND1 GND2
Figure 7.6 TPD7106F Output part.
© 2 019 7 2020-01-16 Toshiba Electronic Devices & Storage Corporation
