Datasheet TPD7107F (Toshiba) - 2
ПроизводительToshiba
ОписаниеIntelligent Power Device Silicon Power MOS Integrated Circuit
Страниц / Страница34 / 2 — TPD7107F. 4. Block Diagram. Figure 4.1 Block Diagram
TPD7107F 4 Block Diagram Figure 4.1 Block Diagram
14 предложений от 6 поставщиков
Driver 1-OUT High Side Automotive 10-Pin WSON EP Tube
Зенер
Россия и страны ТС
TPD7107F,BXH
от 96 ₽
Элитан
TPD7107F.BXH
Toshiba
158 ₽
TPD7107F,BXH
Toshiba
от 229 ₽
Hi-Tech Circuit Group
TPD7107F,BXH
TPD7107F 4. Block Diagram
. Note: Since a function is explained, it may have omit ed in part and may have simplified the functional block in a block, the circuit, the constant, etc.
© 2 020 2 2020-04-09 Toshiba Electronic Devices & Storage Corporation Document Outline 1. Description 2. Uses 3. Features 4. Block Diagram 5. Pin Assignments 6. Pin Description 7. Operational Description 7.1. Protection for reverse connection of power supply 7.2. Active clamp 7.3. Gate drive of Power MOSFET (Off driver) 7.3.1. Normal off, rapid off 7.3.2. Protection for disconnection of GND terminal 7.4. Load current sense at time of Power MOSFET drive 7.5. The abnormalities in power supply voltage (VDD over voltage, VDD under voltage) 7.6. Over current protection 7.7. Over temperature protection. 7.8. Abnormalities in voltage between Drain and source of the external FET (VDS error) 7.9. Load open / VDD short of load line and diagnosis output 7.10. Truth Table 7.11. State Transition Diagram 8. Absolute Maximum Ratings 8.1. Thermal Resistance 9. Operating Ranges 10. Electrical Characteristics 10.1. Electrical characteristics 1 10.2. Electrical characteristics 2 10.3. Current sense amp Electrical Characteristics 11. Test Circuit 11.1. Test circuit 1 High level output voltage (3) 11.2. Test circuit 2 Switching time (Td-ON, Td-OFF, Tr, Tf) 11.3. Test circuit 3 Off impedance at GND open 11.4. Test circuit 4 Input offset voltage 12. Characteristic curves 13. Package Information 13.1. Package Dimensions 13.2. Marking 13.3. Land Pattern Dimensions for Reference only 14. IC Usage Notes 14.1. Notes on Handling of ICs 14.2. Notes on mounting. RESTRICTIONS ON PRODUCT USE
