Линейка продуктов KEEN SIDE
Datasheet ADA4522-2-KGD (Analog Devices) - 6
Описание55 V, EMI Enhanced, Zero Drift, Ultralow Noise, Rail-to-Rail Output Operational Amplifier
Страниц / Страница10 / 6 — ADA4522-2-KGD. Known Good Die. ELECTRICAL CHARACTERISTICS—55 V OPERATION. …
Формат / Размер файлаPDF / 240 Кб
ADA4522-2-KGD. Known Good Die. ELECTRICAL CHARACTERISTICS—55 V OPERATION. Table 3. Parameter Symbol. Test. Conditions/Comments. Min
ADA4522-2-KGD Known Good Die ELECTRICAL CHARACTERISTICS—55 V OPERATION Table 3 Parameter Symbol Test Conditions/Comments Min
33 предложений от 13 поставщиков
ADA4522-2ARMZ-RL
140 ₽
Зенер
Россия и страны ТС
ADA4522-2ARMZ-RL
от 230 ₽
ADA4522-2ARMZ-RL
390 ₽
ADA4522-2ARMZ-RL
от 618 ₽
VSY = 55 V, VCM = VSY/2 V, TA = 25°C, unless otherwise specified.
Table 3. Parameter Symbol Test Conditions/Comments Min Typ Max Unit
INPUT CHARACTERISTICS Offset Voltage VOS VCM = VSY/2 1.5 7 μV −40°C ≤ TA ≤ +125°C 10 μV Offset Voltage Drift ΔVOS/ΔT 6 30 nV/°C Input Bias Current IB 50 150 pA −40°C ≤ TA ≤ +85°C 500 pA −40°C ≤ TA ≤ +125°C 4.5 nA Input Offset Current IOS 80 300 pA −40°C ≤ TA ≤ +85°C 400 pA −40°C ≤ TA ≤ +125°C 500 pA Input Voltage Range IVR 0 53.5 V Common-Mode Rejection Ratio CMRR VCM = 0 V to 53.5 V 140 144 dB −40°C ≤ TA ≤ +125°C 135 dB Large Signal Voltage Gain AVO RL = 10 kΩ, VOUT = 0.5 V to 54.5 V 135 137 dB −40°C ≤ TA ≤ +125°C 125 dB Input Resistance Differential Mode RINDM 30 kΩ Common Mode RINCM 1000 GΩ Input Capacitance Differential Mode CINDM 7 pF Common Mode CINCM 35 pF OUTPUT CHARACTERISTICS Output Voltage High VOH RL = 10 kΩ to VSY/2 54.75 54.8 V −40°C ≤ TA ≤ +125°C 54.65 V Output Voltage Low VOL RL = 10 kΩ to VSY/2 200 250 mV −40°C ≤ TA ≤ +125°C 350 mV Continuous Output Current IOUT Dropout voltage = 1 V 14 mA Short-Circuit Current Source ISC+ 21 mA TA = 125°C 15 mA Short-Circuit Current Sink ISC− 32 mA TA = 125°C 22 mA Closed-Loop Output Impedance ZOUT Frequency = 1 MHz, AV = +1 4 Ω POWER SUPPLY Power Supply Rejection Ratio PSRR VSY = 4.5 V to 55 V 150 160 dB −40°C ≤ TA ≤ +125°C 145 dB Supply Current per Amplifier ISY IOUT = 0 mA 830 900 μA −40°C ≤ TA ≤ +125°C 950 μA Rev. 0 | Page 6 of 10 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS—5.0 V OPERATION ELECTRICAL CHARACTERISTICS—30 V OPERATION ELECTRICAL CHARACTERISTICS—55 V OPERATION ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS OUTLINE DIMENSIONS DIE SPECIFICATIONS AND ASSEMBLY RECOMMENDATIONS ORDERING GUIDE
