Datasheet ADA4096-2, ADA4096-4 (Analog Devices) - 3
Описание30 V, Micropower, Overvoltage Protection, Rail-to-Rail Input/Output Amplifiers
Страниц / Страница25 / 3 — Data Sheet. ADA4096-2/ADA4096-4. REVISION HISTORY 9/2017—Rev. F to Rev. …
ВерсияG
Формат / Размер файлаPDF / 640 Кб
Data Sheet. ADA4096-2/ADA4096-4. REVISION HISTORY 9/2017—Rev. F to Rev. G. 8/2012—Rev. A to Rev. B. 12/2014—Rev. E to Rev. F
Data Sheet ADA4096-2/ADA4096-4 REVISION HISTORY 9/2017—Rev F to Rev G 8/2012—Rev A to Rev B 12/2014—Rev E to Rev F
23 предложений от 14 поставщиков
ADA4096-2WARMZ-RL
205 ₽
Рутоника
ADA4096-2WARMZ-RL
272 ₽
ADA4096-2WARMZ-RL
324 ₽
ADA4096-2WARMZ-RL
Data Sheet ADA4096-2/ADA4096-4 REVISION HISTORY 9/2017—Rev. F to Rev. G 8/2012—Rev. A to Rev. B
Changed ADA409x to ADA4096-2 .. Throughout Added ADA4096-4 .. Universal Changed CP-16-27 to CP-16-22 .. Throughout Changes to Features Section .. 1 Changes to Figure 12 and Figure 13 ... 10 Added Figure 3 .. 1 Changes to Figure 26 .. 13 Changes to Pin Connection Diagrams Section ... 1 Changes to Figure 39 .. 16 Changes to Input Bias Current, Common-Mode Rejection Updated Outline Dimensions .. 22 Ratio, Large Signal Voltage Gain, and Supply Current per Changes to Ordering Guide ... 24 Amplifier Parameters, and −3 dB Closed-Loop Bandwidth Symbol, Table 2 .. 3
Changes to Input Bias Current, Common-Mode Rejection Changes to EPAD Note, Figure 2 .. 1 Ratio, Large Signal Voltage Gain, and Parameters, and −3 dB Changes to EPAD Note, Figure 5 and Table 7 ... 7 Closed-Loop Bandwidth Symbol, Table 3 ... 4 Changes to EPAD Note, Figure 7 and Table 8 ... 8 Changes to Input Bias Current, Common-Mode Rejection Ratio, Large Signal Voltage Gain, Output Voltage High, and
3/2014—Rev. D to Rev. E
Output Voltage Low Parameters, and −3 dB Closed-Loop Changes to Figure 10 and Figure 12 ... 9 Bandwidth Symbol, Table 4 ... 5 Changes to Figure 23 and Figure 25 ... 12 Changes to Table 6 .. 7 Changes to Figure 36 and Figure 38 ... 15 Added Pin Configurations and Function Descriptions Section .. 8
5/2013—Rev. C to Rev. D
Added Figure 4 and Figure 5, Renumbered Sequential y .. 8 Changes to Pin Connection Diagrams Section ... 1 Added Table 7, Renumbered Sequential y ... 8 Changes to Pin Configurations and Function Descriptions Added Figure 6, Figure 7, and Table 8 .. 9 Section .. 7 Updated Outline Dimensions.. 18 Added Figure 10, Renumbered Sequentially ... 9 Changes to Ordering Guide ... 20 Added Figure 23 .. 12 Added Figure 36 .. 15
3/2012—Rev. 0 to Rev. A
Changed −3 dB Closed-Loop Bandwidth from 97 kHz to
8/2012—Rev. B to Rev. C
970 kHz, Table 2 .. 3 Changes to Table 8 .. 8 Changed −3 dB Closed-Loop Bandwidth from 114 kHz to 1140 kHz, Table 3 .. 4 Changed to −3 dB Closed-Loop Bandwidth from 152 kHz to 1520 kHz, Table 4 .. 5 Updated Outline Dimensions.. 18
7/2011—Revision 0: Initial Version
Rev. G | Page 3 of 25 Document Outline Features Applications Pin Connection Diagrams General Description Revision History Specifications Electrical Specifications, VSY = ±1.5 V Electrical Specifications, VSY = ±5 V Electrical Specifications, VSY = ±15 V Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics ±1.5 V Characteristics ±5 V Characteristics ±15 V Characteristics Comparative Voltage and Variable Voltage Graphs Theory of Operation Input Stage Phase Inversion Input Overvoltage Protection Comparator Operation Outline Dimensions Ordering Guide Automotive Products
