Datasheet AD822 (Analog Devices) - 4
ОписаниеSingle-Supply, Rail-to-Rail Low Power FET-Input Op Amp
Страниц / Страница24 / 4 — AD822. Data Sheet. SPECIFICATIONS. Table 1. A Grade. B Grade. Parameter. …
ВерсияJ
Формат / Размер файлаPDF / 529 Кб
AD822. Data Sheet. SPECIFICATIONS. Table 1. A Grade. B Grade. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit
AD822 Data Sheet SPECIFICATIONS Table 1 A Grade B Grade Parameter Test Conditions/Comments Min Typ Max Unit
49 предложений от 24 поставщиков
Операционный усилитель сдвоенный маломощный уровень входа/выхода до напряжения питания ±15В/30В
AD822ARMZ
от 143 ₽
AD822ARMZ-R2
355 ₽
727GS
AD822ARMZ
5 363 ₽
AD822ARMZ
АЦП азиатских производителей
VS = 0 V, 5 V at TA = 25°C, VCM = 0 V, VOUT = 0.2 V, unless otherwise noted.
Table 1. A Grade B Grade Parameter Test Conditions/Comments Min Typ Max Min Typ Max Unit
DC PERFORMANCE Initial Offset 0.1 0.8 0.1 0.4 mV Maximum Offset Over Temperature 0.5 1.2 0.5 0.9 mV Offset Drift 2 2 µV/°C Input Bias Current VCM = 0 V to 4 V 2 25 2 10 pA At TMAX 0.5 5 0.5 2.5 nA Input Offset Current 2 20 2 10 pA At TMAX 0.5 0.5 nA Open-Loop Gain VOUT = 0.2 V to 4 V RL = 100 kΩ 500 1000 500 1000 V/mV TMIN to TMAX 400 400 V/mV RL = 10 kΩ 80 150 80 150 V/mV TMIN to TMAX 80 80 V/mV RL = 1 kΩ 15 30 15 30 V/mV TMIN to TMAX 10 10 V/mV NOISE/HARMONIC PERFORMANCE Input Voltage Noise f = 0.1 Hz to 10 Hz 2 2 µV p-p f = 10 Hz 25 25 nV/√Hz f = 100 Hz 21 21 nV/√Hz f = 1 kHz 16 16 nV/√Hz f = 10 kHz 13 13 nV/√Hz Input Current Noise f = 0.1 Hz to 10 Hz 18 18 fA p-p f = 1 kHz 0.8 0.8 fA/√Hz Harmonic Distortion RL = 10 kΩ to 2.5 V f = 10 kHz VOUT = 0.25 V to 4.75 V −93 −93 dB DYNAMIC PERFORMANCE Unity-Gain Frequency 1.8 1.8 MHz Full Power Response VOUT p-p = 4.5 V 210 210 kHz Slew Rate 3 3 V/µs Settling Time To 0.1% VOUT = 0.2 V to 4.5 V 1.4 1.4 µs To 0.01% VOUT = 0.2 V to 4.5 V 1.8 1.8 µs MATCHING CHARACTERISTICS Initial Offset 1.0 0.5 mV Maximum Offset Over Temperature 1.6 1.3 mV Offset Drift 3 3 µV/°C Input Bias Current 20 10 pA Crosstalk @ f = 1 kHz RL = 5 kΩ −130 –130 dB Crosstalk @ f = 100 kHz RL = 5 kΩ −93 –93 dB Rev. J | Page 4 of 24 Document Outline FEATURES APPLICATIONS CONNECTION DIAGRAM GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE MAXIMUM POWER DISSIPATION ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION INPUT CHARACTERISTICS OUTPUT CHARACTERISTICS SINGLE-SUPPLY VOLTAGE TO FREQUENCY CONVERTER LOW DROPOUT BIPOLAR BRIDGE DRIVER OUTLINE DIMENSIONS ORDERING GUIDE
