Datasheet OP200 (Analog Devices) - 7
ОписаниеDual Low Offset, Low Power Operational Amplifier
Страниц / Страница16 / 7 — Data Sheet. OP200. ABSOLUTE MAXIMUM RATINGS. THERMAL RESISTANCE. Table 5. …
ВерсияG
Формат / Размер файлаPDF / 363 Кб
Data Sheet. OP200. ABSOLUTE MAXIMUM RATINGS. THERMAL RESISTANCE. Table 5. Parameter. Rating. Table 6. Package Type. θ 1. θJC. Unit
Data Sheet OP200 ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE Table 5 Parameter Rating Table 6 Package Type θ 1 θJC Unit
14 предложений от 12 поставщиков
IC OPAMP GP 2 CIRCUIT 20CLCC. General Purpose Amplifier 2 Circuit 20-CLCC (8.89x8.89). Linear - Amplifiers - Instrumentation, OP Amps, Buffer...
ЧипСити
5962-8859301M2A
6 440 ₽
Рутоника
5962-8859301M2A
10 797 ₽
5962-8859301M2A
от 11 553 ₽
5962-8859301M2A
16 373 ₽
Data Sheet OP200 ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE Table 5. Parameter Rating Table 6.
Supply Voltage ±20 V
Package Type θ 1 JA θJC Unit
Differential Input Voltage ±30 V 8-Lead CERDIP (Z Suffix) 148 16 °C/W Input Voltage Supply voltage 8-Lead Plastic DIP (P Suffix) 96 37 °C/W Output Short-Circuit Duration Continuous 16-Lead SOIC (S Suffix) 92 27 °C/W Storage Temperature Range −65°C to +150°C 1 Lead Temperature (Soldering, 60 sec) 300°C θJA is specified for worst-case mounting conditions, that is, θJA is specified for device in socket for CERDIP and PDIP packages; θJA is specified for device Junction Temperature Range (TJ) −65°C to +150°C soldered to printed circuit board for SOIC package. Operating Temperature Range
ESD CAUTION
OP200A −55°C to +125°C OP200E, OP200G −40°C to +85°C Stresses at or above those listed under Absolute Maximum Ratings may cause permanent damage to the product. This is a stress rating only; functional operation of the product at these or any other conditions above those indicated in the operational section of this specification is not implied. Operation beyond the maximum operating conditions for extended periods may affect product reliability. Rev. G | Page 7 of 16 Document Outline FEATURES PIN CONNECTIONS GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION DUAL LOW POWER INSTRUMENTATION AMPLIFIER PRECISION ABSOLUTE VALUE AMPLIFIER PRECISION CURRENT PUMP DUAL 12-BIT VOLTAGE OUTPUT DAC DUAL PRECISION VOLTAGE REFERENCE PROGRAMMABLE HIGH RESOLUTION WINDOW COMPARATOR OUTLINE DIMENSIONS ORDERING GUIDE
