Клеммные колодки Keen Side
Datasheet LAN9303, LAN9303i (Microchip) - 4
ПроизводительMicrochip
ОписаниеSmall Form Factor Three Port 10/100 Managed Ethernet Switch with Single MII/RMII/Turbo MII
Страниц / Страница6 / 4 — Block Diagram. Figure 1 Internal Block Diagram
Формат / Размер файлаPDF / 240 Кб
Block Diagram Figure 1 Internal Block Diagram
33 предложений от 19 поставщиков
Чип интерфейса, Microchip LAN9303-ABZJ, 3Port Ethernet Switch, MII/RMII, 10Mbps, 100Mbps 3.3V, 56Pin QFN
LAN9303-ABZJ
от 150 ₽
LAN9303-ABZJ
от 377 ₽
Элитан
LAN9303-ABZJ
1 020 ₽
LAN9303-ABZJ
от 1 051 ₽
I 1) MI
Block Diagram
o urb -08-1 I/T I/RMI n 1.5 (07 MI ingle S MII/Turbo MII to PHY or Revisio MII/RMII/Turbo MII to MAC itch with w S net Virtual PHY her MDIO Registers 4 Queu Ethernet D 4 Queu D MDIO 10/100 Por Por MDIO Qo yna Qo yna MII ged Et To optional SMI Master PHY MII 10/100 10/100 t 1 S m S m t 0 Data MII MAC es i es i MAC Registers c c Path Mode MDIO MUX PHY Management Mode Configuration Interface (PMI) Search Straps /100 Mana Switch Engine Engine 10 rt Mode Configuration SMI (slave) o MDIO Buffer Manager Frame Straps P Buffers Controller e 4 Que Dynam Por QoS Switch Register 4 PREVIEW or Thre MII t 10/100 I2C Slave 2 Registers Access u act Ethernet 10/100 MAC es ic Controller (CSRs) MUX PHY MDIO System Registers Switch Fabric Registers PRODUCT all Form F (CSRs) m S EEPROM Loader To optional EEPROM System GP Timer (via I2C master) System GPIO/LED Clocks/ EEPROM Controller I2C Interrupt Control er Reset/PME I2C (master) To optional CPU LAN9303/ Controller Free-Run Controller serial management Clk LAN9303i (via I2C slave) To optional GPIOs/LEDs IRQ External LAN9303i 25MHz Crystal
SMSC LAN9303/ Document Outline General Description Block Diagram Figure 1 Internal Block Diagram Package Outline 56-QFN Package Outline Figure 2 56-QFN Package Definition Table 1 56-QFN Dimensions Figure 3 56-QFN Recommended PCB Land Pattern
