Datasheet HMC862A (Analog Devices) - 10
Описание0.1 GHz to 24 GHz, Low Noise, Programmable Divider
Страниц / Страница15 / 10 — HMC862A. Data Sheet. DIVIDE BY 8. R (. +85°C. VCC = 5.25V. +25°C. VCC = …
ВерсияA
Формат / Размер файлаPDF / 483 Кб
HMC862A. Data Sheet. DIVIDE BY 8. R (. +85°C. VCC = 5.25V. +25°C. VCC = 5.00V. –40°C. VCC = 4.75V. SINE WAVE INPUT FREQUENCY (GHz). MAX PIN
HMC862A Data Sheet DIVIDE BY 8 R ( +85°C VCC = 5.25V +25°C VCC = 5.00V –40°C VCC = 4.75V SINE WAVE INPUT FREQUENCY (GHz) MAX PIN
24 предложений от 11 поставщиков
Высокочастотная техника и средства высокочастотной идентификации ВЧ сплиттеры
Рутоника
HMC862ALP3ETR
1 585 ₽
727GS
HMC862ALP3ETR
от 1 601 ₽
Microfind
HMC862ALP3ETR
3 441 ₽
HMC862ALP3ETR
от 4 416 ₽
HMC862A Data Sheet DIVIDE BY 8 6 6 5 5 4 ) 4 ) Bm Bm d 3 d 3 R ( R ( E E W 2 W O 2 O P P UT 1 UT P 1 P UT UT O O 0 0 +85°C VCC = 5.25V –1 +25°C –1 VCC = 5.00V –40°C VCC = 4.75V –2 –2 0 2 4 6 8 10 12 14 16 18 20 22 24
45 46 0
0 9- 9-
59
59 13 13 Figure 21. Output Power vs. Sine Wave Input Frequency for Various Figure 24. Output Power vs. Sine Wave Input Frequency for Various Vcc Temperatures, PIN = 0 dBm Voltages, PIN = 0 dBm
15 0 MAX PIN 10 –10 5 ) –20 Bm) m d B +85°C 0 +25°C R ( (d E R –40°C –30 E W O W –5 P PO IC –40 T N –10 O PU IN RM –50 –15 HA MIN PIN –60 FEEDTHROUGH –20 SECOND HARMONIC THIRD HARMONIC –25 –70
8
35 04 0
0 0.5 1.0 1.5 2.0 2.5 3.0
9- 99-
59
OUTPUT FREQUENCY (GHz)
135 13 Figure 22. Allowable Range of Input Power vs. Sine Wave Input Frequency Figure 25. Output Harmonics, PIN = 0 dBm, TA = 25°C for Various Temperatures
–115 –115 SQUARE 100MHz PIN = +10dBm –120 SINE 100MHz (5dBm) –120 PIN = +5dBm SINE 18GHz PIN = 0dBm –125 SINE 12GHz –125 PIN = –5dBm z) SINE 6GHz z) PIN = –10dBm c/H –130 c/H –130 B B d –135 ( –135 E ISE (d IS O –140 O N –140 N SE E –145 A –145 HAS PH –150 –150 B P SSB S S –155 –155 –160 –160 –165 –165
0
100 1k 10k 100k 1M
49 0 05 9-
100 1k 10k 100k 1M OFFSET FREQUENCY (Hz)
359 1
13599- Figure 23. SSB Phase Noise vs. Offset Frequency for Various Input Figure 26. SSB Phase Noise vs. Offset Frequency for Various Input Power (PIN) Frequencies, PIN = 0 dBm, TA = 25°C Levels, fIN = 12 GHz Sine Wave, TA = 25°C Rev. A | Page 10 of 15 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS RF SPECIFICATIONS DC SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS DIVIDE BY 1 DIVIDE BY 2 DIVIDE BY 4 DIVIDE BY 8 CURRENT CONSUMPTION (ICC) THEORY OF OPERATION INPUT INTERFACE OUTPUT INTERFACE APPLICATIONS INFORMATION EVALUATION PRINTED CIRCUIT BOARD (PCB) EVALUATION BOARD OVERVIEW OUTLINE DIMENSIONS ORDERING GUIDE
