Datasheet DMN3012LEG (Diodes) - 2
ПроизводительDiodes
Описание30V Synchronous N-Channel Enhancement Mode MOSFET
Страниц / Страница10 / 2 — DMN3012LEG. Maximum Ratings. Characteristic. Symbol. Unit. Thermal …
Формат / Размер файлаPDF / 611 Кб
DMN3012LEG. Maximum Ratings. Characteristic. Symbol. Unit. Thermal Characteristics. Value. Electrical Characteristics. Min. Typ. Max
DMN3012LEG Maximum Ratings Characteristic Symbol Unit Thermal Characteristics Value Electrical Characteristics Min Typ Max
23 предложений от 9 поставщиков
Транзистор: MOSFET BVDSS: 25V-30V POWERDI333
DMN3012LEG-7
Diodes
99 ₽
DMN3012LEG-7
Diodes
от 116 ₽
DMN3012LEG-7
129 ₽
Hi-Tech Circuit Group
DMN3012LEG-7
Diodes
(@TA = +25°C, unless otherwise specified.)
Characteristic Symbol Q1 Q2 Unit
Drain-Source Voltage VDSS 30 V Gate-Source Voltage VGSS ±10 V T 20 C = +25C ID A TC = +70C 16 Continuous Drain Current @ VGS = 5V T 10 A = +25C ID A TA = +70C 8 Pulsed Drain Current (10μs Pulse, Duty Cycle = 1%) IDM 70 100 A Continuous Source-Drain Diode Current (Note 5) IS 2.7 3.2 A Avalanche Current (Note 6) L = 0.1mH IAS 34 50 A Avalanche Energy (Note 6) L = 0.1mH EAS 58 125 mJ HBM 300 V ESD Capability(Note 9) CDM 1000 V
Characteristic Symbol Value Unit
T 2.2 Total Power Dissipation C = +25° C PD W TC = +70°C 1.4 Steady State 58 Thermal Resistance, Junction to Ambient (Note 5) RJA t<10s 36 °C/W Thermal Resistance, Junction to Case (Note 5) RJC 9.5 Operating and Storage Temperature Range TJ, TSTG -55 to +150 °C
Electrical Characteristics Q1
Characteristic Symbol Min Typ Max Unit Test Condition OFF CHARACTERISTICS (Note 7)
Drain-Source Breakdown Voltage BVDSS 30 — — V VGS = 0V, ID = 250μA Zero Gate Voltage Drain Current IDSS — — 1 μA VDS = 20V, VGS = 0V Gate-Source Leakage IGSS — — ±100 nA VGS = ±10V, VDS = 0V
ON CHARACTERISTICS (Note 7)
Gate Threshold Voltage VGS(TH) 1 — 2.1 V VDS = VGS, ID = 250μA Static Drain-Source On-Resistance RDS(ON) — 10.5 12 mΩ VGS = 5V, ID = 15A Diode Forward Voltage VSD — — 1.0 V VGS = 0V, IS = 15A
DYNAMIC CHARACTERISTICS (Note 8)
Input Capacitance Ciss — 650 850 V Output Capacitance Coss — 314 410 pF DS = 15V, VGS = 0V, f = 1.0MHz Reverse Transfer Capacitance Crss — 12 16 V Gate Resistance R DS = 0V, VGS = 0V, f = g — 1.63 3.3 Ω 1.0MHz Total Gate Charge (VGS = 4.5V) Qg — 4.7 6.1 Total Gate Charge at VTH Qg(TH) — 0.91 — nC VDS = 15V, ID = 15A Gate-Source Charge Qgs — 1.6 — Gate-Drain Charge Qgd — 0.9 — Turn-On Delay Time tD(ON) — 5.1 7.7 Turn-On Rise Time tR — 2.7 — V ns DD = 15V, VGS = 4.5V, Turn-Off Delay Time tD(OFF) — 6.4 9.6 ID = 15A, Rg = 2Ω Turn-Off Fall Time tF — 2.3 — Reverse Recovery Time tRR — 24.5 — ns IF = 15A, di/dt = 300A/μs Reverse Recovery Charge QRR — 8.3 — nC Notes: 5. Device mounted on FR-4 substrate PC board, 2oz copper, with 1inch square copper plate. 6. IAS and EAS ratings are based on low frequency and duty cycles to keep TJ = +25°C. 7. Short duration pulse test used to minimize self-heating effect. 8. Guaranteed by design. Not subject to product testing. 9. Based on characterization data only. Not subject to production testing. DMN3012LEG 2 of 10 March 2019 Document number: DS41633 Rev. 2 - 2
www.diodes.com
© Diodes Incorporated
