Клеммники KEEN SIDE
Datasheet AD7294 (Analog Devices) - 4
Описание12-Bit Monitor and Control System with Multichannel ADC, DACs, Temperature Sensor, and Current Sense
Страниц / Страница47 / 4 — AD7294. Data Sheet. FUNCTIONAL BLOCK DIAGRAM. RSENSE. TO LOAD. REF. OUT/. …
ВерсияI
AD7294. Data Sheet. FUNCTIONAL BLOCK DIAGRAM. RSENSE. TO LOAD. REF. OUT/. AVDD. AGND DAC OUT. VPP(1 TO 2). RS1(+) RS1(–) RS2(+). RS2(–) REF
AD7294 Data Sheet FUNCTIONAL BLOCK DIAGRAM RSENSE TO LOAD REF OUT/ AVDD AGND DAC OUT VPP(1 TO 2) RS1(+) RS1(–) RS2(+) RS2(–) REF
32 предложений от 16 поставщиков
Микросхема Цифро-аналоговый преобразователь, ANALOG DEVICES AD7294BCPZ Analogue to Digital Converter, 12Bit, 22.22KSPS, Single, 4.5V, 5.5V, LFCSP
AD7294BCPZ
585 ₽
AD7294BCPZ
1 088 ₽
AD7294BCPZ
1 819 ₽
AD7294BCPZ
AD7294 Data Sheet FUNCTIONAL BLOCK DIAGRAM RSENSE TO LOAD REF REF OUT/ OUT/ AVDD AGND DAC OUT VPP(1 TO 2) RS1(+) RS1(–) RS2(+) RS2(–) REF REF IN ADC IN DAC (1 TO 6) (1 TO 7) V+ AB/CD HIGH SIDE HIGH SIDE 2.5V CURRENT CURRENT REF 100kΩ 200kΩ SENSE SENSE 12-BIT DAC ISENSE2 OVERRANGE V V OUTA REF 10.41 ISENSE1 OVERRANGE 100kΩ 200kΩ OFFSET IN A VIN0 100kΩ 200kΩ V 12-BIT IN1 12-BIT DAC V MUX IN2 ADC VIN3 VOUTB D1+ D2+ LIMIT 100kΩ 200kΩ REGISTERS OFFSET IN B 100kΩ 200kΩ 12-BIT T1 T2 DAC D2– TEMP V SENSOR OUTC D1– 100kΩ 200kΩ OFFSET IN C 100kΩ 200kΩ 12-BIT CONTROL LOGIC AD7294 DAC VOUTD I2C INTERFACE PROTOCOL 100kΩ 200kΩ OFFSET IN D
001
DV SDA SCL AS2 AS1 DD DGND AS0 DCAP ALERT/ (1 TO 2) BUSY
05747- Figure 1. Rev. I | Page 4 of 47 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY FUNCTIONAL BLOCK DIAGRAM SPECIFICATIONS DAC SPECIFICATIONS ADC SPECIFICATIONS GENERAL SPECIFICATIONS TIMING CHARACTERISTICS I2C Serial Interface Timing and Circuit Diagrams ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY DAC TERMINOLOGY ADC TERMINOLOGY THEORY OF OPERATION ADC OVERVIEW ADC TRANSFER FUNCTIONS ANALOG INPUTS Single-Ended Mode Differential Mode Driving Differential Inputs Using an Op Amp Pair Pseudo Differential Mode CURRENT SENSOR Choosing RSENSE Current Sense Filtering Kelvin Sense Resistor Connection ANALOG COMPARATOR LOOP TEMPERATURE SENSOR Remote Sensing Diode Ideality Factor Base Emitter Voltage Base Resistance hFE Variation Series Resistance Cancellation DAC OPERATION Resistor String Output Amplifier ADC AND DAC REFERENCE VDRIVE FEATURE REGISTER SETTING ADDRESS POINTER REGISTER COMMAND REGISTER (0x00) RESULT REGISTER (0x01) ADC Channel Allocation TSENSE1, TSENSE2 RESULT REGISTERS (0X02 AND 0X03) TSENSEINT RESULT REGISTER (0X04) Temperature Value Format DACA, DACB, DACC, DACD, REGISTERS (0x01 TO 0x04) ALERT STATUS REGISTER A (0x05), REGISTER B (0x06), AND REGISTER C (0x07) CHANNEL SEQUENCE REGISTER (0x08) CONFIGURATION REGISTER (0x09) Sample Delay and Bit Trial Delay POWER-DOWN REGISTER (0x0A) DATAHIGH/DATALOW REGISTERS: 0x0B, 0x0C (VIN0); 0x0E, 0x0F (VIN1); 0x11, 0x12 (VIN2); 0x14, 0x15 (VIN3) HYSTERESIS REGISTERS: 0X0D (VIN0), 0X10 (VIN1), 0X13 (VIN2), 0X16 (VIN3) TSENSE OFFSET REGISTERS (0x26 AND 0x27) I2C INTERFACE GENERAL I2C TIMING SERIAL BUS ADDRESS BYTE INTERFACE PROTOCOL Writing a Single Byte of Data to an 8-Bit Register Writing Two Bytes of Data to a 16-Bit Register Writing to Multiple Registers Reading Data from an 8-Bit Register Reading Two Bytes of Data from a 16-Bit Register MODES OF OPERATION COMMAND MODE AUTOCYCLE MODE ALERTS AND LIMITS THEORY ALERT_FLAG BIT ALERT STATUS REGISTERS DATAHIGH AND DATALOW MONITORING FEATURES HYSTERESIS Using the Limit Registers to Store Minimum/Maximum Conversion Results APPLICATIONS INFORMATION BASE STATION POWER AMPLIFIER MONITOR AND CONTROL GAIN CONTROL OF POWER AMPLIFIER LAYOUT AND CONFIGURATION POWER SUPPLY BYPASSING AND GROUNDING Layout Considerations for External Temperature Sensors OUTLINE DIMENSIONS ORDERING GUIDE
