Datasheet FSD176MRT (ON Semiconductor) - 2
Производитель | ON Semiconductor |
Описание | Green-Mode Fairchild Power Switch (FPS ) |
Страниц / Страница | 19 / 2 — FSD176MRT. Green-Mode Fairchild Power Switch (FPS™) |
Версия | A |
Формат / Размер файла | PDF / 849 Кб |
Язык документа | английский |
12 предложений от 12 поставщиков Интегральные микросхемы Микросхемы управления электропитанием - AC/DC преобразователи |
| FSD176MRTLDTU ON Semiconductor | 72 ₽ | |
| FSD176MRTLDTU ON Semiconductor | 78 ₽ | |
| FSD176MRTLDTU ON Semiconductor | по запросу | |
| FSD176MRTLDTU Fairchild | по запросу | |
FSD176MRT
Features Description Advanced Soft Burst-Mode Operation for The FSD176MRT is an integrated Pulse Width
Modulation (PWM) controller and SenseFET specifically
designed for offline Switch-Mode Power Supplies
(SMPS) with minimal external components. The PWM
controller includes an integrated fixed-frequency
oscillator, Under-Voltage Lockout (UVLO), LeadingEdge Blanking (LEB), optimized gate driver, internal
soft-start, temperature-compensated precise current
sources for loop compensation, and self-protection
circuitry. Compared with a discrete MOSFET and PWM
controller solution, the FSD176MRT can reduce total
cost, component count, size, and weight; while
simultaneously increasing efficiency, productivity, and
system reliability. This device provides a basic platform
for cost-effective design of a flyback converter. Low Standby Power and Low Audible Noise Random Frequency Fluctuation for Low EMI
Pulse-by-Pulse Current Limit
Various Protection Functions: Overload Protection (OLP), Over-Voltage Protection (OVP), Abnormal
Over-Current Protection (AOCP), Internal Thermal
Shutdown (TSD) with Hysteresis, Output-Short
Protection (OSP), and Under-Voltage Lockout (UVLO)
with Hysteresis Low Operating Current (0.4 mA) in Burst Mode
Internal Startup Circuit
Internal High-Voltage SenseFET: 650 V
Built-in Soft-Start: 15 ms
Auto-Restart Mode
Applications
Power Supply for LCD Monitor, STB, and
DVD Combination Ordering Information
(2) Output Power Table
Part Number Package Operating
Current RDS(ON)
Junction
Limit (Max.)
Temperature 230 VAC ±15%(3)
Adapter(4) 85~265 VAC Open
Open
(4)
(5) Adapter
(5)
Frame
Frame Replaces
Device TO-220
FSD176MRTUDT 6-Lead(1)
-40°C ~ +125°C 3.50 A
UU
Forming 1.6 Ω 80 W 90 W 48 W 70 W FSGM0765
R TO-220
6-Lead(1)
-40°C ~ +125°C 3.50A
FSD176MRTLDTU
LForming 1.6Ω 80W 90W 48W 70 W FSGM0765
R Notes:
1. Pb-free package per JEDEC J-STD-020B.
2. The junction temperature can limit the maximum output power.
3. 230 VAC or 100 / 115 VAC with voltage doubler.
4. Typical continuous power in a non-ventilated enclosed adapter measured at 50°C ambient temperature.
5. Maximum practical continuous power in an open-frame design at 50°C ambient temperature.
© 2011 Fairchild Semiconductor Corporation
FSD176MRT • Rev. 1.0.1 www.fairchildsemi.com FSD176MRT — Green-Mode Fairchild Power Switch (FPS™) January 2014
