Datasheet SiZF300DT (Vishay) - 3
ПроизводительVishay
ОписаниеDual N-Channel 30 V (D-S) MOSFET with Schottky Diode
Страниц / Страница13 / 3 — SiZF300DT. SPECIFICATIONS. PARAMETER SYMBOL. TEST. CONDITIONS. MIN. TYP. …
Формат / Размер файлаPDF / 265 Кб
SiZF300DT. SPECIFICATIONS. PARAMETER SYMBOL. TEST. CONDITIONS. MIN. TYP. MAX. UNIT. Drain-Source Body Diode Characteristics. Notes
SiZF300DT SPECIFICATIONS PARAMETER SYMBOL TEST CONDITIONS MIN TYP MAX UNIT Drain-Source Body Diode Characteristics Notes
19 предложений от 8 поставщиков
Полупроводники - Дискретные
Зенер
Россия и страны ТС
SIZF300DT-T1-GE3
от 40 ₽
SIZF300DT-T1-GE3
82 ₽
SIZF300DT-T1-GE3
Yageo
от 136 ₽
Hi-Tech Circuit Group
SIZF300DT-T1-GE3
SiZF300DT
www.vishay.com Vishay Siliconix
SPECIFICATIONS
(TJ = 25 °C, unless otherwise noted)
PARAMETER SYMBOL TEST CONDITIONS MIN. TYP. MAX. UNIT Drain-Source Body Diode Characteristics
Ch-1 - - 44 Continuous source-drain diode current IS TC = 25 °C Ch-2 - - 105 A Ch-1 - - 150 Pulse diode forward current a ISM Ch-2 - - 200 IS = 5 A, VGS = 0 V Ch-1 - 0.75 1.1 Body diode voltage VSD V IS = 5 A, VGS = 0 V Ch-2 - 0.44 0.7 Ch-1 - 36 75 Body diode reverse recovery time trr ns Ch-2 - 46 90 Channel-1 Ch-1 - 26 55 Body diode reverse recovery charge Q I rr F = 10 A, di/dt = 100 A/μs, TJ = 25 °C nC Ch-2 - 40 80 Ch-1 - 16 - Reverse recovery fall time ta Channel-2 Ch-2 - 18 - IF = 10 A, di/dt = 100 A/μs, TJ = 25 °C ns Ch-1 - 20 - Reverse recovery rise time tb Ch-2 - 28 -
Notes
a. Guaranteed by design, not subject to production testing b. Pulse test; pulse width  300 μs, duty cycle  2 % Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. S18-0479-Rev. A, 30-Apr-2018
3
Document Number: 76288 For technical questions, contact: pmostechsupport@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
