Клеммники KEEN SIDE
Datasheet SiZF300DT (Vishay) - 9
ПроизводительVishay
ОписаниеDual N-Channel 30 V (D-S) MOSFET with Schottky Diode
Страниц / Страница13 / 9 — SiZF300DT. CHANNEL-2 TYPICAL CHARACTERISTICS. Source-Drain Diode Forward …
Формат / Размер файлаPDF / 265 Кб
SiZF300DT. CHANNEL-2 TYPICAL CHARACTERISTICS. Source-Drain Diode Forward Voltage. On-Resistance vs. Gate-to-Source Voltage
SiZF300DT CHANNEL-2 TYPICAL CHARACTERISTICS Source-Drain Diode Forward Voltage On-Resistance vs Gate-to-Source Voltage
14 предложений от 7 поставщиков
Полупроводники - Дискретные
SIZF300DT-T1-GE3
от 13 ₽
SIZF300DT-T1-GE3
106 ₽
SIZF300DT-T1-GE3
Yageo
от 136 ₽
Hi-Tech Circuit Group
SIZF300DT-T1-GE3
SiZF300DT
www.vishay.com Vishay Siliconix
(25 °C, unless otherwise noted) Axis Title Axis Title 100 10000 0.005 10000 I = 10 A D T = 150 °C J ) 0.004 ) Ω (A T = 25 °C 10 J 1000 1000 T = 125 °C J rrent 0.003 u ne ne ine ne ne ine Resistance ( 1st li 2nd li 2nd l 1st li 2nd l n- 0.002 2nd li ource C O 1 100 S - 100 - (on) I S S T = 25 °C J D 0.001 R 0.1 10 0 10 0 0.2 0.4 0.6 0.8 1.0 0 2 4 6 8 10 V - Source-to-Drain Voltage (V) V - Gate-to-Source Voltage (V) SD GS 2nd line 2nd line
Source-Drain Diode Forward Voltage On-Resistance vs. Gate-to-Source Voltage
Axis Title Axis Title 1.E-01 10000 50 10000 1.E-02 40 1.E-03 1000 1000 ) (V 30 1.E-04 V = 30 V DS ne ne I r ine ne ne r (W e 1.E-05 1st li w 2nd li 1st li 2nd l o 20 2nd li P V = 10 V 100 100 DS 1.E-06 10 1.E-07 1.E-08 10 0 10 -50 -25 0 25 50 75 100 125 150 0.001 0.01 0.1 1 10 100 1000 T - Temperature (°C) Time (s) J 2nd line 2nd line
Reverse Current (Schottky) Single Pulse Power, Junction-to-Ambient
Axis Title 1000 10000 I Limited by R (1) DM Limited ID(ON) Limited DS(on) 100 ) 100 μs 1000 10 rrent (A ine u 1 ms C n 2nd l 1 10 ms rai D 100 ms 100 - I D 1s 0.1 10 s DC T = 25 °C A Single pulse BVdss Limited 0.01 10 0.01 0.1 1 10 100 V - Drain-to-Source Voltage (V) DS (1) V > minimum V at which R is specified GS GS DS(on)
Safe Operating Area, Junction-to-Ambient
S18-0479-Rev. A, 30-Apr-2018
9
Document Number: 76288 For technical questions, contact: pmostechsupport@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
