Клеммники KEEN SIDE
Datasheet AP7348 (Diodes) - 10
ПроизводительDiodes
Описание4 Channel 300MA High PSRR Low Noise LDO With Enable
Страниц / Страница15 / 10 — AP7348. Application Information. Output Capacitor. Input Capacitor. …
AP7348. Application Information. Output Capacitor. Input Capacitor. Enable Control. R P. Short Circuit Protection
AP7348 Application Information Output Capacitor Input Capacitor Enable Control R P Short Circuit Protection
29 предложений от 8 поставщиков
LDO Voltage Regulator, 4 Output, Fixed, 1.7-5.25V in, 340 mV Drop, 1.2/1.8V/300 mA out, X1DFN1612-EP
AP7348D-1218RS4-7
Diodes
9.80 ₽
AP7348D-1218RS4-7
Diodes
от 22 ₽
AP7348D-1218RS4-7
Diodes
от 34 ₽
Hi-Tech Circuit Group
AP7348D-1218RS4-7
Diodes
An output capacitor (COUT) is needed to improve transient response and maintain stability. The AP7348 is stable with very small ceramic output capacitors. The ESR (equivalent series resistance) and capacitance drives the selection. If the application has large load variations, it is recommended to utilize low-ESR bulk capacitors. It is recommended to place ceramic capacitors as close as possible to the load and the ground pin and care should be taken to reduce the impedance in the layout.
Input Capacitor
To prevent the input voltage from dropping during load steps, it is recommended to utilize an input capacitor (CIN). A minimum 4.7μF ceramic capacitor is recommended between VDD and GND pins to decouple input power supply glitch. This input capacitor must be located as close as
T
possible to the device to assure input stability and reduce noise. For PCB layout, a wide copper trace is required for both VDD and GND pins.
C U Enable Control D
The AP7348 is turned on by setting the EN pin high, and is turned off by pulling it low. When EN1 (EN2) pin pull high, the CH1 and CH3 (CH2 and
O
CH4) are turned on at the same time. If this feature is not used, the EN pins should be tied to VDD pin to keep the regulator output on at all times.
R P
To ensure proper operation, the signal source used to drive the EN pins must be able to swing above and below the specified turn-on/off voltage thresholds listed in the Electrical Characteristics section.
W E Short Circuit Protection N
When VOUT pin is short-circuit to GND, short circuit protection will be triggered and clamp the output current to approximately 55mA. This feature protects the regulator from overcurrent and damage due to overheating.
Layout Considerations
For good ground loop and stability, the input and output capacitors should be located close to the input, output, and ground pins of the device. The regulator ground pin should be connected to the external circuit ground to reduce voltage drop caused by trace impedance. Ground plane is generally used to reduce trace impedance. Wide trace should be used for large current paths from VIN to VOUT, and load circuit.
ESR vs. Output Current
Ceramic type output capacitor is recommended for this series; however, the other output capacitors with low ESR also can be used. The relations between IOUT (Output Current) and ESR of an output capacitor are shown below. The stable region is marked as the hatched area in the graph. Measurement conditions: Frequency Band: 10Hz to 2MHz, Temperature: -40°C to +85°C. AP7348 10 of 15 October 2019 Document number: DS42124 Rev. 2 - 2
www.diodes.com
© Diodes Incorporated
