Datasheet ADL5906 (Analog Devices) - 3
Описание10 MHz TO 10 GHz 67 dB TruPwr Detector
Страниц / Страница32 / 3 — Data Sheet. ADL5906. SPECIFICATIONS. Table 1. Parameter. Test …
ВерсияA
Формат / Размер файлаPDF / 1.9 Мб
Data Sheet. ADL5906. SPECIFICATIONS. Table 1. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit
Data Sheet ADL5906 SPECIFICATIONS Table 1 Parameter Test Conditions/Comments Min Typ Max Unit
25 предложений от 13 поставщиков
Высокочастотная техника и средства высокочастотной идентификации ВЧ детекторы
Рутоника
ADL5906ACPZN-R7
609 ₽
ADL5906ACPZN-R7
948 ₽
ADL5906ACPZN-R7
727GS
ADL5906ACPZN-R7
VPOS1 = VPOS2 = 5 V, TA = 25°C, single-ended input drive, RT = 60.4 Ω, VRMS connected to VSET, VTGT = 0.8 V, CRMS = 0.1 µF. Negative current values imply that the ADL5906 is sourcing current out of the indicated pin.
OVERALL FUNCTION Frequency Range 10 to 10,000 MHz RF INPUT INTERFACE RFIN+, Pin RFIN− (Pin 14, Pin 15), ac-coupled Input Impedance Single-ended drive, 50 MHz 2500 Ω Common-Mode Voltage 2.5 V 100 MHz ±1.0 dB Dynamic Range Continuous wave (CW) input, TA = 25°C 62 dB Maximum Input Level, ±1.0 dB Calibration at −55 dBm, −40 dBm, and 0 dBm 2 dBm Minimum Input Level, ±1.0 dB Calibration at −55 dBm, −40 dBm, and 0 dBm −60 dBm Deviation vs. Temperature Deviation from output at 25°C, VTADJ = 0.35 V −40°C < TA < +85°C; PIN = 0 dBm −0.8/+0.2 dB −40°C < TA < +85°C; PIN = −45 dBm −0.8/+0.4 dB −55°C < TA < +125°C; PIN = 0 dBm −1.3/+0.2 dB −55°C < TA < +125°C; PIN = −45 dBm −1.2/+0.6 dB Logarithmic Slope −65 dBm < PIN < +10 dBm; calibration at −40 dBm and 0 dBm 59 mV/dB Logarithmic Intercept −65 dBm < PIN < +10 dBm; calibration at −40 dBm and 0 dBm −64 dBm 700 MHz ±1.0 dB Dynamic Range CW input, TA = 25°C 62 dB Maximum Input Level, ±1.0 dB Calibration at −55 dBm, −40 dBm, and 0 dBm 2 dBm Minimum Input Level, ±1.0 dB Calibration at −55 dBm, −40 dBm, and 0 dBm −60 dBm Deviation vs. Temperature Deviation from output at 25°C, VTADJ = 0.35 V −40°C < TA < +85°C; PIN = 0 dBm −0.9/+0.3 dB −40°C < TA < +85°C; PIN = −45 dBm −0.9/+0.4 dB −55°C < TA < +125°C; PIN = 0 dBm −1.5/+0.3 dB −55°C < TA < +125°C; PIN = −45 dBm −1.3/+0.7 dB Logarithmic Slope −65 dBm < PIN < +10 dBm; calibration at −40 dBm, and 0 dBm 59 mV/dB Logarithmic Intercept −65 dBm < PIN < +10 dBm; calibration at −40 dBm and 0 dBm −65 dBm 900 MHz ±1.0 dB Dynamic Range CW input, TA = 25°C 63 dB Maximum Input Level, ±1.0 dB Calibration at −55 dBm, −40 dBm, and 0 dBm 3 dBm Minimum Input Level, ±1.0 dB Calibration at −55 dBm, −40 dBm, and 0 dBm −60 dBm Deviation vs. Temperature Deviation from output at 25°C, VTADJ = 0.35 V −40°C < TA < +85°C; PIN = 0 dBm −0.8/+0.3 dB −40°C < TA < +85°C; PIN = −45 dBm −0.9/+0.4 dB −55°C < TA < +125°C; PIN = 0 dBm −1.4/+0.3 dB −55°C < TA < +125°C; PIN = −45 dBm −1.4/+0.8 dB Logarithmic Slope −65 dBm < PIN < +10 dBm; calibration at −40 dBm and 0 dBm 59 mV/dB Logarithmic Intercept −65 dBm < PIN < +10 dBm; calibration at −40 dBm and 0 dBm −65 dBm Deviation from CW Response 12.16 dB peak-to-rms ratio (four-carrier W-CDMA) −0.1 dB (−45 dBm to −5 dBm) 11.58 dB peak-to-rms ratio (LTE TM1, one-carrier, 20 MHz −0.2 dB bandwidth) 10.56 dB peak-to-rms ratio (W-CDMA) 0.05 dB 7.4 dB peak-to-rms ratio (64 QAM) −0.1 dB Rev. A | Page 3 of 32 Document Outline Features Applications Functional Block Diagram General Description Table of Contents Revision History Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Square Law Detector and Amplitude Target RF Input Interface Temperature Sensor Interface VREF Interface Temperature Compensation Interface Power-Down Interface VSET Interface Output Interface VTGT Interface Basis for Error Calculations Measurement Mode Basic Connections Setting VTADJ Setting VTGT Choosing a Value for CRMS Output Voltage Scaling System Calibration and Error Calculation Using VTEMP to Improve Intercept Temperature Drift Description of Characterization Evaluation Board Evaluation Board Assembly Drawings Outline Dimensions Ordering Guide
