Datasheet ADL5505 (Analog Devices) - 4
Описание450 MHz TO 6000 MHz TruPwr Detector
Страниц / Страница20 / 4 — ADL5505. Parameter. Test Conditions. Min. Typ. Max. Unit
ВерсияA
ADL5505 Parameter Test Conditions Min Typ Max Unit
15 предложений от 12 поставщиков
IC RF DETECT 450MHZ-6GHZ 4WLCSP. RF Detector IC LTE, WiMax 450MHz ~ 6GHz -22dBm ~ 15dBm ±0.25dB 4-WFBGA, WLCSP. RF Detectors...
ADL5505ACBZ-P7
154 ₽
ЧипСити
ADL5505ACBZ-P7
154 ₽
ADL5505ACBZ-P7
253 ₽
Рутоника
ADL5505ACBZ-P7
255 ₽
link to page 3 link to page 3 link to page 3 link to page 3 link to page 3 link to page 3 link to page 3 link to page 3 link to page 3 link to page 3 link to page 3 link to page 3 link to page 3 link to page 3 link to page 3 link to page 3 link to page 3 link to page 3 link to page 3 link to page 3 link to page 3 link to page 3 link to page 3 link to page 3 link to page 5 link to page 5 link to page 5 link to page 5 link to page 5 link to page 5 link to page 5 link to page 5 link to page 5 link to page 5 link to page 5 link to page 5 link to page 5 link to page 5
RF INPUT (f = 1900 MHz) Input RFIN to output VRMS Input Impedance No termination 270||0.67 Ω||pF RMS Conversion Dynamic Range1 Continuous wave (CW) input, −40°C < TA < +85°C ±0.25 dB Error2 Delta from 25°C 21 dB ±0.25 dB Error3 16 dB ±1 dB Error3 36 dB ±2 dB Error3 40 dB Maximum Input Level ±0.25 dB error3 15 dBm Minimum Input Level ±1 dB error3 −22 dBm Conversion Gain VRMS = (gain × VIN) + intercept 1.82 V/V rms Output Intercept4 0.007 V Output Voltage, High Input Power PIN = 5 dBm, 400 mV rms 0.727 V Output Voltage, Low Input Power PIN = −15 dBm, 40 mV rms 0.079 V Temperature Sensitivity PIN = 0 dBm +25°C < TA < +85°C 0.0017 dB/°C −40°C < TA < +25°C −0.0026 dB/°C RF INPUT (f = 2600 MHz) Input RFIN to output VRMS Input Impedance No termination 240||0.58 Ω||pF RMS Conversion Dynamic Range1 Continuous wave (CW) input, −40°C < TA < +85°C ±0.25 dB Error2 Delta from 25°C 14 dB ±0.25 dB Error3 11 dB ±1 dB Error3 35 dB ±2 dB Error3 40 dB Maximum Input Level ±0.25 dB error3 15 dBm Minimum Input Level ±1 dB error3 −22 dBm Conversion Gain VRMS = (gain × VIN) + intercept 1.77 V/V rms Output Intercept4 0.005 V Output Voltage, High Input Power PIN = 5 dBm, 400 mV rms 0.700 V Output Voltage, Low Input Power PIN = −15 dBm, 40 mV rms 0.075 V Temperature Sensitivity PIN = 0 dBm +25°C < TA < +85°C 0.0016 dB/°C −40°C < TA < +25°C 0.0042 dB/°C RF INPUT (f = 3500 MHz) Input RFIN to output VRMS Input Impedance No termination 210||0.48 Ω||pF RMS Conversion Dynamic Range1 Continuous wave (CW) input, −40°C < TA < +85°C ±0.25 dB Error2 Delta from 25°C 5 dB ±0.25 dB Error3 5 dB ±1 dB Error3 33 dB ±2 dB Error3 39 dB Maximum Input Level ±0.25 dB error3 13 dBm Minimum Input Level ±1 dB error3 −21 dBm Conversion Gain VRMS = (gain × VIN) + intercept 1.61 V/V rms Output Intercept4 0.001 V Output Voltage, High Input Power PIN = 5 dBm, 400 mV rms 0.630 V Output Voltage, Low Input Power PIN = −15 dBm, 40 mV rms 0.065 V Temperature Sensitivity PIN = 0 dBm +25°C < TA < +85°C 0.0046 dB/°C −40°C < TA < +25°C 0.0085 dB/°C Rev. A | Page 4 of 20 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Circuit Description RMS Circuit Description and Filtering Filtering Output Buffer Applications Information Basic Connections RF Input Interfacing Resistive Tap RF Input Multiple RF Inputs Linearity Output Swing Output Offset Output Drive Capability and Buffering Selecting the Output Low-Pass Filter Power Consumption Device Calibration and Error Calculation Calibration for Improved Accuracy Drift Over a Reduced Temperature Range Device Handling Land Pattern and Soldering Information Evaluation Board Outline Dimensions Ordering Guide
