Datasheet HMC1021LP4E (Analog Devices) - 4
ОписаниеRMS Power Detector SMT, with Envelope Tracker, DC - 3.9 GHz
Страниц / Страница26 / 4 — HMC1021LP4E. RMS POWER DETECTOR &. ENVELOPE TRACKER, DC - 3.9 GHz. …
Формат / Размер файлаPDF / 2.5 Мб
HMC1021LP4E. RMS POWER DETECTOR &. ENVELOPE TRACKER, DC - 3.9 GHz. Electrical Specifications II. Modulation Deviation
HMC1021LP4E RMS POWER DETECTOR & ENVELOPE TRACKER, DC - 3.9 GHz Electrical Specifications II Modulation Deviation
12 предложений от 11 поставщиков
Радиочастотный детектор , RF Detector 0MHz to 3900MHz 10dBm 24Pin QFN EP T/R
131352-HMC1021LP4E
65 ₽
Элитан
HMC1021LP4E
923 ₽
HMC1021LP4E
1 029 ₽
727GS
HMC1021LP4E
HMC1021LP4E
v02.0511
TA = +25 °C, Vcc = 5V, Sci4 = Sci1 = 0V, Sci3 = Sci2 = 5V, Unless Otherwise Noted Parameter typ. typ. typ. typ. typ. typ. typ. Units Input Frequency 100 900 1900 2200 2700 3500 3900 MHz
(Output deviation from reference, which is measured with CW input at equivalent input signal power) WCDMA 4 Carrier (TM1-64 DPCH) at +25 °C 0.1 0.1 0.1 0.1 0.1 0.1 0.1 dB WCDMA 4 Carrier (TM1-64 DPCH) at +85 °C 0.1 0.1 0.1 0.1 0.1 0.1 0.1 dB WCDMA 4 Carrier (TM1-64 DPCH) at -40 °C 0.1 0.1 0.1 0.1 0.1 0.1 0.1 dB
RMSOUT Logarithmic Slope and Intercept
[1] Logarithmic slope 33.6 33.7 34.1 34.5 35.4 37.8 39.7 mV/dB Logarithmic Intercept -69.4 -69.2 -68.4 -67.8 -66.2 -62.2 -59.3 dBm Max. Input Power at ±1dB error 8 8 8 8 8 7 5 dBm Min. Input Power at ±1dB error -63 -63 -62 -61 -60 -57 -55 dBm 11
ETOUT Linear Slope and Intercept
Linear slope 16.6 16.0 14.8 14.5 13.6 12.3 11.3 V/V t Linear Intercept -56.0 -58.2 -63.0 -64.0 -68.0 -75.3 -81.8 mV Max. Input Power at ±1dB error -14 -13 -11 -11 -10 -10 -9 dBm M Min. Input Power at ±1dB error -32 -32 -31 -30 -30 -29 -28 dBm s [1] With WCDMA 4 Carrier (TM1-64 DPCH) - rs
RMSOUT vs. Pin with Different RMSOUT Error vs. Pin with Different
o
Modulations @ 1900 MHz [1] Modulations @ 1900 MHz [1]
t 3 4 c CW e 3 2.5 Ideal WCDMA 4 carriers t CW 2 WCDMA1 WCDMA 4 carriers CDMA2000 e 2 WCDMA1 CDMA2000 1 LTEDW LTEDW D 1.5 0 r RMSOUT (V) -1 1 ERROR (dB) e -2 w 0.5 -3 o 0 -4 P -70 -60 -50 -40 -30 -20 -10 0 10 -70 -60 -50 -40 -30 -20 -10 0 10 INPUT POWER (dBm) INPUT POWER (dBm) [1] Data was taken at sci4=sci1=0V, sci3=sci2=5V, shortest integration time is for scI=0000, allowed longest integration time is for scI=1100 For price, delivery and to place orders: Hittite Microwave Corporation, 20 Alpha Road, Chelmsford, MA 01824 Phone: 978-250-3343 Fax: 978-250-3373 Order On-line at www.hittite.com
11 - 2
Application Support: Phone: 978-250-3343 or apps@hittite.com Document Outline Typical Applications Features Functional Diagram General Descriptions Electrical Specifications I Electrical Specifications II RMSOUT vs. Pin with Different Modulations @ 1900 MHz RMSOUT Error vs. Pin with Different Modulations @ 1900 MHz Electrical Specifications III Typical Performance Characteristics RMSOUT & Error vs. Pin @ 100 MHz RMSOUT & Error vs. Pin @ 900 MHz RMSOUT & Error vs. Pin @ 1900 MHz RMSOUT & Error vs. Pin @ 2200 MHz RMSOUT & Error vs. Pin @ 2700 MHz RMSOUT & Error vs. Pin @ 3500 MHz RMSOUT & Error vs. Pin @ 3900 MHz RMSOUT Intercept vs. Frequency RMSOUT Slope vs. Frequency RMSOUT vs. Pin with WCDMA 4 Carrier @ +25 °C RMSOUT Error vs. Pin with WCDMA 4 Carrier @ +25 °C RMSOUT Error vs. Pin with WCDMA 4 Carrier @ +85 °C wrt +25 °C Response RMSOUT Error vs. Pin with WCDMA 4 Carrier @ -40 °C wrt +25 °C Response RMSOUT vs. Pin with CW @ +25 °C RMSOUT Error vs. Pin with CW @ +25 °C RMSOUT vs. Pin w/ CW & WCDMA 4 Carrier @ 1900 MHz & +25 °C Reading Error for WCDMA 4 Carrier wrt CW Response @ +25 °C RMSOUT vs. Pin w/ CW & WCDMA 4 Carrier @ 1900 MHz & +85 °C Reading Error for WCDMA 4 Carrier wrt CW Response @ +85 °C RMSOUT vs. Pin w/ CW & WCDMA 4 Carrier @ 1900 MHz & -40 °C Reading Error for WCDMA 4 Carrier wrt CW Response @ -40 °C RMSOUT Output Response with SCI = 0000 @ 1900 MHz RMSOUT Output Response with SCI = 1100 @ 1900 MHz Typical Supply Current vs. Pin, Vcc = 5V Input Return Loss vs. Frequency Output Ripple & Rise/Fall Time vs. Integration Setting [Sci4,Sci3,Sci2,Sci1] in Decimal ETOUT vs. Pin with CW @ 900 MHz ETOUT & ETOUT Error vs. Pin with CW @ 900 MHz ETOUT & ETOUT Error vs. Pin with CW @ 1900 MHz ETOUT vs. Pin with CW @ 3500 MHz ETOUT & ETOUT Error vs. Pin with CW @ 3500 MHz ETOUT Intercept vs. Frequency with CW ETOUT Slope vs. Frequency with CW Absolute Maximum Ratings Outline Drawing Package Information Pin Descriptions Evaluation PCB List of Materials Application Circuit Application Information Principle of Operation Configuration For The Typical Application Broadband Single-Ended Input Interface RMSOUT & Error vs. Pin Envelope Detector Output ETOUT Bandwidth ETOUT Response to an RF Input Signal with a 100 MHz Modulation Bandwidth RMS Output Interface and Transient Response Table 1: Transient Response vs. SCI Setting Rise Time vs. SCI Setting over Input Power Rise Settling Time vs. SCI Setting over Input Power Fall Time vs. SCI Setting over Input Power Residual Ripple for 900 MHz WiMAX @ SCI=0100 Residual Ripple for 900 MHz WiMAX @ SCI=0101 Residual Ripple for 900 MHz WiBRO @ SCI=0100 Residual Ripple for 900 MHz WiBRO@ SCI=0110 Residual Ripple for 900 MHz LTE Downlink @ SCI=0100 Residual Ripple for 900 MHz LTE Downlink @ SCI=0110 Residual Ripple for 900 MHz WCDMA4 @ SCI=0011 Residual Ripple for 900 MHz WCDMA4 @ SCI=0100 LOG-Slope and Intercept Slope Adjustment Intercept Adjustment DC Offset Compensation Loop Standby Mode Modulation Performance - Crest factor performance Reading Error for WCDMA 4 Carrier wrt CW Response @ +25 °C Reading Error for WCDMA 4 Carrier wrt CW Response @ 2200 MHz RMSOUT Error vs. Crest Factor over Frequency System Calibration Layout Considerations Definitions
