Datasheet HMC1020LP4E (Analog Devices) - 8
ОписаниеRMS Power Detector SMT, Single-Ended, DC - 3.9 GHz
Страниц / Страница24 / 8 — HMC1020LP4E. RMS POWER DETECTOR. SINGLE-ENDED, DC - 3.9 GHz
Формат / Размер файлаPDF / 2.1 Мб
HMC1020LP4E RMS POWER DETECTOR SINGLE-ENDED, DC - 3.9 GHz
Радиочастотный детектор , RF Detector 100MHz to 3900MHz 7dBm 24Pin QFN EP T/R
HMC1020LP4E
710 ₽
HMC1020LP4E
841 ₽
HMC1020LP4E
924 ₽
EVAL01-HMC1020LP4E
АЦП азиатских производителей
HMC1020LP4E
v02.0511
RMS POWER DETECTOR SINGLE-ENDED, DC - 3.9 GHz RMSOUT Error vs. Pin with WCDMA 4 Carrier @ -40 °C wrt +25 °C Response [1] RMSOUT vs. Pin with CW @ +25 °C [1]
4 3 3 100MHz 100MHz 900MHz 2.5 900MHz 1900MHz 1900MHz 2 2200MHz 2200MHz 2700MHz 2700MHz 3500MHz 2 1 3500MHz 3900MHz (V) (dB) 3900MHz 0 1.5 ERROR -1 RMSOUT 1 -2 0.5 -3 -4 0 -70 -60 -50 -40 -30 -20 -10 0 10 -70 -60 -50 -40 -30 -20 -10 0 10 11 INPUT POWER (dBm) INPUT POWER (dBm) t
RMSOUT vs. Pin w/ CW & WCDMA 4 Carrier
M
RMSOUT Error vs. Pin with CW @ +25 °C [1] @ 1900 MHz & +25 °C [1]
s 4 3 - 3 2.5 2 rs 2 CW 1 WCDMA o (V) (dB) t 0 1.5 c ERROR -1 100MHz RMSOUT 1 e 900MHz -2 1900MHz t 2700MHz 2200MHz 0.5 e -3 3500MHz 3900MHz -4 0 D -70 -60 -50 -40 -30 -20 -10 0 10 -70 -60 -50 -40 -30 -20 -10 0 10 r INPUT POWER (dBm) INPUT POWER (dBm) e w
Reading Error for WCDMA 4 Carrier wrt RMSOUT vs. Pin w/ CW & WCDMA 4 Carrier
o
CW Response @ +25 °C [1] @ 1900 MHz & +85 °C [1]
P 1 3 0.8 0.6 2.5 0.4 2 CW 0.2 WCDMA (dB) (V) 0 1.5 -0.2 ERROR 100MHz RMSOUT -0.4 900MHz 1 1900MHz -0.6 2200MHz 2700MHz 0.5 -0.8 3500MHz 3900MHz -1 0 -70 -60 -50 -40 -30 -20 -10 0 10 -70 -60 -50 -40 -30 -20 -10 0 10 INPUT POWER (dBm) INPUT POWER (dBm) [1] Data was taken at sci4=sci1=0V, sci3=sci2=5V, shortest integration time is for scI=0000, allowed longest integration time is for scI=1100 For price, delivery and to place orders: Hittite Microwave Corporation, 20 Alpha Road, Chelmsford, MA 01824 Phone: 978-250-3343 Fax: 978-250-3373 Order On-line at www.hittite.com
11 - 6
Application Support: Phone: 978-250-3343 or apps@hittite.com Document Outline Typical Applications Features Functional Diagram General Descriptions Electrical Specifications I Electrical Specifications II RMSOUT vs. Pin with Different Modulations @ 1900 MHz RMSOUT Error vs. Pin with Different Modulations @ 1900 MHz Electrical Specifications III Typical Performance Characteristics RMSOUT & Error vs. Pin @ 100 MHz RMSOUT & Error vs. Pin @ 900 MHz RMSOUT & Error vs. Pin @ 1900 MHz RMSOUT & Error vs. Pin @ 2200 MHz RMSOUT & Error vs. Pin @ 2700 MHz RMSOUT & Error vs. Pin @ 3500 MHz RMSOUT & Error vs. Pin @ 3900 MHz Intercept vs. Frequency Slope vs. Frequency RMSOUT vs. Pin with WCDMA 4 Carrier @ +25 °C RMSOUT Error vs. Pin with WCDMA 4 Carrier @ +25 °C RMSOUT Error vs. Pin with WCDMA 4 Carrier @ +85 °C wrt +25 °C Response RMSOUT Error vs. Pin with WCDMA 4 Carrier @ -40 °C wrt +25 °C Response RMSOUT vs. Pin with CW @ +25 °C RMSOUT Error vs. Pin with CW @ +25 °C RMSOUT vs. Pin w/ CW & WCDMA 4 Carrier @ 1900 MHz & +25 °C Reading Error for WCDMA 4 Carrier wrt CW Response @ +25 °C RMSOUT vs. Pin w/ CW & WCDMA 4 Carrier @ 1900 MHz & +85 °C Reading Error for WCDMA 4 Carrier wrt CW Response @ +85 °C RMSOUT vs. Pin w/ CW & WCDMA 4 Carrier @ 1900 MHz & -40 °C Reading Error for WCDMA 4 Carrier wrt CW Response @ -40 °C Output Response with SCI = 0000 @ 1900 MHz Output Response with SCI = 1100 @ 1900 MHz Typical Supply Current vs. Pin, Vcc = 5V Input Return Loss vs. Frequency Output Ripple & Rise/Fall Time vs. Integration Setting [Sci4,Sci3,Sci2,Sci1] in Decimal Absolute Maximum Ratings Outline Drawing Package Information Pin Descriptions Evaluation PCB List of Materials Evaluation Order Information Application Circuit Application Information Principle of Operation Configuration For The Typical Application Broadband Single-Ended Input Interface RMSOUT & Error vs. Pin RMS Output Interface and Transient Response Table 1: Transient Response vs. SCI Setting Rise Time vs. SCI Setting over Input Power Rise Settling Time vs. SCI Setting over Input Power Fall Time vs. SCI Setting over Input Power Residual Ripple for 900 Mhz WiMAX @ SCI=0100 Residual Ripple for 900 Mhz WiMAX @ SCI=0110 Residual Ripple for 900 Mhz WiBRO @ SCI=0100 Residual Ripple for 900 Mhz WiBRO @ SCI=0110 Residual Ripple for 900 Mhz LTE Downlink @ SCI=0100 Residual Ripple for 900 Mhz LTE Downlink @ SCI=0110 Residual Ripple for 900 Mhz WCDMA4 @ SCI=0011 Residual Ripple for 900 Mhz WCDMA4 @ SCI=0100 LOG-Slope and Intercept Slope Adjustment Intercept Adjustment DC Offset Compensation Loop Standby Mode Modulation Performance - Crest factor performance Reading Error for WCDMA 4 Carrier wrt CW Response @ +25 °C Reading Error for WCDMA 4 Carrier wrt CW Response @ 2200MHz RMSOUT Error vs. Crest Factor over Frequency System Calibration Layout Considerations Definitions
