Datasheet ADL5500 (Analog Devices) - 9
| Производитель | Analog Devices |
| Описание | 100 MHz to 6 GHz TruPwr Detector |
| Страниц / Страница | 24 / 9 — Data Sheet. ADL5500. TYPICAL PERFORMANCE CHARACTERISTICS. 100MHz 450MHz … |
| Версия | B |
| Формат / Размер файла | PDF / 1.7 Мб |
Data Sheet. ADL5500. TYPICAL PERFORMANCE CHARACTERISTICS. 100MHz 450MHz 900MHz. 1900MHz 2350MHz 2700MHz 3900MHz. OUTPUT (V)
Data Sheet ADL5500 TYPICAL PERFORMANCE CHARACTERISTICS
TA = 25°C, VS = 5.0 V, CFLT = 10 nF, light condition ≤ 600 LUX, Colors: black = +25°C, blue = −40°C, red = +85°C, unless otherwise noted.
10 3 100MHz 450MHz 900MHz 2 1900MHz 2350MHz 2700MHz 3900MHz 1 1 0 OUTPUT (V) ERROR (dB) 0.1 100MHz –1 450MHz 900MHz 1900MHz 2350MHz –2 2700MHz 3900MHz 0.03
05546-004
–3
05546-007
–25 –20 –15 –10 –5 0 5 10 15 –25 –20 –15 –10 –5 0 5 10 15 INPUT (dBm) INPUT (dBm)
Figure 4. Output vs. Input Level, Frequencies 100 MHz, 450 MHz, 900 MHz, Figure 7. Linearity Error vs. Input Level, Frequencies 100 MHz, 450 MHz, 1900 MHz, 2350 MHz, 2700 MHz, and 3900 MHz, Supply 5.0 V 900 MHz, 1900 MHz, 2350 MHz, 2700 MHz, and 3900 MHz, Supply 5.0 V
5.0 10 5.5V 4.5 5.0V 4.0 2.7V 3.5 3.0V 3.0 1 (V) T PU 2.5 T U O 2.0 OUTPUT (V) 1.5 100MHz 450MHz 1.0 900MHz 0.1 1900MHz 0.5 2350MHz 2700MHz 3900MHz 0 0.03
05546-008
0 0.2 0.4 0.6 0.8 1.0 1.2 1.4
005
–25 –20 –15 –10 –5 0 5 10 15 INPUT (V rms) INPUT (dBm)
05546- Figure 5. Output vs. Input Level (Linear Scale), Frequencies 100 MHz, 450 MHz, Figure 8. Output vs. Input Level, 900 MHz,1900 MHz, 2350 MHz, 2700 MHz, and 3900 MHz, Supply 5.0 V Supply 2.7 V, 3.0 V, 5.0 V, and 5.5 V, Frequency 900 MHz
11 25 10 9 8 3.0V 20 5.0V 7 6 15 5 4 RETURN LOSS (dB) SUPPLY CURRENT (mA) 3 10 2 1 0
05546-006
5
05546-009
0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 0 1 2 3 4 5 6 INPUT (V rms) FREQUENCY (GHz)
Figure 6. Supply Current vs. Input Level, Supplies 3.0 V and 5.0 V, Figure 9. Return Loss vs. Frequency Temperatures −40°C, +25°C, and +85°C Rev. B | Page 9 of 24 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS CIRCUIT DESCRIPTION FILTERING APPLICATIONS INFORMATION BASIC CONNECTIONS OUTPUT SWING LINEARITY INPUT COUPLING USING A SERIES RESISTOR MULTIPLE RF INPUTS SELECTING THE OUTPUT LOW-PASS FILTER NETWORK POWER CONSUMPTION AND POWER-ON/-OFF RESPONSE OUTPUT DRIVE CAPABILITY AND BUFFERING VRMS OUTPUT OFFSET DEVICE CALIBRATION AND ERROR CALCULATION CALIBRATION FOR IMPROVED ACCURACY DRIFT OVER A REDUCED TEMPERATURE RANGE OPERATION ABOVE 4.0 GHz DEVICE HANDLING EVALUATION BOARD Land Pattern and Soldering Information Junction-to-Board Thermal Impedance OUTLINE DIMENSIONS ORDERING GUIDE
