Datasheet HMC8200LP5ME (Analog Devices) - 8
ОписаниеIntermediate Frequency Transmitter 800 MHz to 4000 MHz
Страниц / Страница25 / 8 — HMC8200LP5ME. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. DGAMAX, TA …
ВерсияD
Формат / Размер файлаPDF / 617 Кб
HMC8200LP5ME. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. DGAMAX, TA = +85°C. DGAMIN, TA = +85°C. DGAMAX, TA = +25°C
HMC8200LP5ME Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS DGAMAX, TA = +85°C DGAMIN, TA = +85°C DGAMAX, TA = +25°C
7 предложений от 7 поставщиков
RF XMITTER 800MHZ-4GHZ 32VFQFN. RF Transmitter 800MHz ~ 4GHz Antenna 32-VFQFN Exposed Pad, CSP. RF Transmitters
HMC8200LP5METR
1 031 ₽
HMC8200LP5METR
2 631 ₽
HMC8200LP5METR
HMC8200LP5METR
HMC8200LP5ME Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 50 50 DGAMAX, TA = +85°C DGAMIN, TA = +85°C DGAMAX, TA = +25°C DGAMIN, TA = +25°C 40 DGAMAX, TA = –40°C DGAMIN, TA = –40°C 40 B) 30 B) 30 d d N ( N ( AI AI 20 20 DGAMAX, TA = +85°C DGAMIN, TA = +85°C N G N G DGAMAX, TA = +25°C DGAMIN, TA = +25°C IO IO DGAMAX, TA = –40°C DGAMIN, TA = –40°C RS 10 RS 10 E E NV NV CO 0 CO 0 –10 –10 –20 –20 0.8 1.2 1.6 2.0 2.4 2.8 3.2 3.6 4.0
002
005
RF FREQUENCY (GHz)
13868-
RF FREQUENCY (GHz)
13868- Figure 3. Conversion Gain vs. RF Frequency Figure 6. Conversion Gain vs. RF Frequency over Temperature, Lower Sideband over Temperature, Upper Sideband
45 90 +85°C +85°C 40 +25°C +25°C –40°C 80 –40°C 35 70 Bc) Bc) d d N ( 30 N ( 60 IO IO CT 25 CT 50 JE JE 20 40 BAND RE 15 BAND RE 30 IDE IDE S 10 S 20 5 10 0 0 0.8 1.2 1.6 2.0 2.4 2.8 3.2 3.6 4.0
003
006
RF FREQUENCY (GHz)
13868-
RF FREQUENCY (GHz)
13868- Figure 4. Sideband Rejection vs. RF Frequency over Temperature, Lower Figure 7. Sideband Rejection vs. RF Frequency over Temperature, Upper Sideband Sideband
40 40 +85°C +85°C +25°C +25°C 35 –40°C 35 –40°C 30 30 25 25 Bm) d Bm) 20 d 20 3 ( 3 ( IP IP 15 15 10 10 5 5 0 0 0.8 1.2 1.6 2.0 2.4 2.8 3.2 3.6 4.0
004
007
RF FREQUENCY (GHz)
13868-
RF FREQUENCY (GHz)
13868- Figure 5. Output IP3 vs. RF Frequency over Temperature, Lower Sideband Figure 8. Output IP3 vs. RF Frequency over Temperature, Upper Sideband Rev. D | Page 8 of 25 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Electrical Characteristics: 800 MHz to 1800 MHz RF Frequency Range Electrical Characteristics: 1800 MHz to 2800 MHz RF Frequency Range Electrical Characteristics: 2800 MHz to 4000 MHz RF Frequency Range Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Register Array Assignments and Serial Interface Read Example Register Descriptions Register Array Assignments Enable Bits Digital Gain Amplifier: DGA Control Digital Gain Amplifier: Amplifier Current, Envelope Level, and VGA Attenuation Bias Image Reject Mixer: Sideband, and Polarity and Offset for I Image Reject Mixer: Polarity and Offset for Q Phase I: Adjust Phase Q: Adjust Evaluation Printed Circuit Board (PCB) Evaluation PCB Schematic Outline Dimensions Ordering Guide
