Datasheet RN42, RN42N (Microchip) - 6
ПроизводительMicrochip
ОписаниеClass 2 Bluetooth Module with EDR Support
Страниц / Страница26 / 6 — RN42/RN42N. TABLE 1-6:. PIN DESCRIPTION. Pin. Symbol. Type. Description. …
RN42/RN42N. TABLE 1-6:. PIN DESCRIPTION. Pin. Symbol. Type. Description. Section 2.8 “SPI Interface”. Section 2.3 “Connection Status”
RN42/RN42N TABLE 1-6: PIN DESCRIPTION Pin Symbol Type Description Section 2.8 “SPI Interface” Section 2.3 “Connection Status”
20 предложений от 15 поставщиков
Высокочастотная техника и средства высокочастотной идентификации Модули РЧ-трансиверов
RN42N-I/RM477
1 040 ₽
727GS
RN42N-I/RM
от 1 242 ₽
Зенер
Россия и страны ТС
RN42N-I/RM
от 3 587 ₽
RN42N-I/RM
1 GND Power Ground reference 2 SPI_MOSI DI (Optional) Factory diagnostic, programming and test. See
. 3 GPIO6 DI Set Bluetooth master. If GPIO6 = high, module connects to the stored address. If GPIO3 = high, module enters new Discovery/Pairing mode. 4 GPIO7 DIO Set baud rate (high = force 9,600, low = 115K or firmware setting) 5 RESET DI Active-low Reset 6 SPI_CLK DI (Optional) Factory diagnostic and test. See
. 7 PCM_CLK DIO (Do not connect) PCM interface(1) 8 PCM_SYNC DIO (Do not connect) PCM interface(1) 9 PCM_IN DI (Do not connect) PCM interface(1) 10 PCM_OUT DO (Do not connect) PCM interface(1) 11 VDD Power Positive Supply 12 GND Power Ground reference 13 UART_RX DI UART receive input 14 UART_TX DO UART transmit output 15 UART_RTS DO UART RTS, goes high to disable host transmitter 16 UART_CTS DI UART CTS, if set high, it disables transmitter 17 USB_D+ DIO USB port. 1.5K pullup activated when USB port is ready (~500 ms after reset). 18 USB_D- DIO USB port 19 GPIO2 DIO Status, high when connected, low otherwise. See
. 20 GPIO3 DI Auto-discovery mode = high. If GPIO6 = high, module performs device enquiry scan searching for a device with matching class of 0x55AA. If a device is found, the address of the device is stored in the remote address field and auto-connects. If GPIO6 = low, module enters Slave mode with special matching class of 0x55AA and waits for a master to discover it. 21 GPIO5 DIO Status, toggles based on state, low on connect. See
. 22 GPIO4 DIO Set factory defaults. See
Section 2.2 “Factory Reset Using GPIO4”
. 23 SPI_CSB DI (Optional) Factory diagnostic and test. See
. 24 SPI_MISO DO (Optional) Factory diagnostic and test. See
. 25 GND Power Ground reference (RN42N only) 26 RF ANT AIO Antenna, 50-Ohm impedance (RN42N only) 27 GND Power Ground reference (RN42N only) 28 GND Power Ground reference 29 GND Power Ground reference 30 AIO0 AIO (Not used) Optional analog input 31 GPIO8 DO UART TX/RX data activity 32 GPIO9 DIO I/O 33 GPIO10 DIO I/O (remote DTR signal) 34 GPIO11 DIO I/O (remote RTS signal) 35 AIO1 AIO (Not used) Optional analog input Pin type abbreviation:
A
= Analog,
D
= Digital,
I
= Input,
O
= Output.
Note 1:
Pin numbers 7 through 10 are reserved for future use. DS50002328A-page 6  2015 Microchip Technology Inc. Document Outline Class 2 Bluetooth® Module with EDR Support Table of Contents 1.0 Device Overview 1.1 MCU Interface 1.2 ASCII Command and Data Interface TABLE 1-1: Environmental Conditions TABLE 1-2: Electrical Characteristics TABLE 1-3: Module Dimensions TABLE 1-4: Radio Characteristics TABLE 1-5: Digital I/O Characteristics TABLE 1-6: Pin Description 2.0 Application Information 2.1 Reset Circuit 2.2 Factory Reset Using GPIO4 2.3 Connection Status TABLE 2-1: GPIO5 Status TABLE 2-2: GPIO2 Status 2.4 Module Mounting Details 2.5 External Antenna Types (RN42N) 2.6 HCI Mode 2.7 Soldering Recommendations 2.8 SPI Interface 2.9 Bluetooth SIG QDID 2.10 Application Schematic 3.0 Regulatory Approval 3.1 United States 3.2 Canada 3.3 Europe TABLE 3-1: RN42 European Compliance Testing 3.4 Australia 3.5 New Zealand 3.6 Japan 3.7 Korea 3.8 Taiwan 4.0 Ordering Information TABLE 4-1: Ordering Information(1) Worldwide Sales and Service
