Datasheet ZXTP56060FDBQ (Diodes)
ПроизводительDiodes
Описание60V Dual PNP LOW VCE(sat) Transistor
Страниц / Страница8 / 1 — ZXTP56060FDBQ. 60V DUAL PNP LOW VCE(sat) TRANSISTOR. Description. …
Формат / Размер файлаPDF / 502 Кб
ZXTP56060FDBQ. 60V DUAL PNP LOW VCE(sat) TRANSISTOR. Description. Mechanical Data. Features. Application
Datasheet ZXTP56060FDBQ Diodes
T-electron
К155470ПКФ1600ВН70493 ₽
ZXTP56060FDBQ 60V DUAL PNP LOW VCE(sat) TRANSISTOR Description Mechanical Data
This bipolar junction transistors (BJT) is designed to meet the • Case: U-DFN2020-6 (SWP) (Type A) with Sidewall Plating stringent requirements of automotive applications. • Case Material: Molded Plastic. “Green” Molding Compound. UL Flammability Rating 94V-0
Features
• Moisture Sensitivity: Level 1 per J-STD-020 • Terminals: Finish—Matte Tin, Solderable per MIL-STD-202, • BVCEO > -60V Method 208 • IC = -2A High Continuous Collector Current • Weight: 0.0065 grams (Approximate) • RCE(sat) = 250mΩ for a Low Equivalent On-Resistance • Sidewall Tin Plating for Wettable Flanks in AOI
• P
Application
D Up to 2.47W for Power Demanding Applications
• Low Profile 0.6mm High Package for Thin Applications
• Matrix LED Lighting •
Totally Lead-Free & Fully RoHS Compliant (Notes 1 & 2)
• Power Management •
Halogen and Antimony Free. “Green” Device (Note 3)
The ZXTP56060FDBQ is suitable for automotive applications requiring specific change control; this part is AEC-Q101 qualified, PPAP capable, and manufactured in IATF16949 certified facilities. https://www.diodes.com/quality/product-definitions/
C1 B2 E2
6
C1 C2
1
E1 B1 C2
Bottom View Device Symbol Top View
Pinout
Ordering Information
(Note 4)
Part Number Marking Reel Size (inches) Tape Width (mm) Quantity Per Reel
ZXTP56060FDBQ-7 2D9 7 8 3000 ZXTP56060FDBQ-13R 2D9 13 8 10,000 Notes: 1. No purposely added lead. Fully EU Directive 2002/95/EC (RoHS), 2011/65/EU (RoHS 2) & 2015/863/EU (RoHS 3) compliant. 2. See https://www.diodes.com/quality/lead-free/ for more information about Diodes Incorporated’s definitions of Halogen- and Antimony-free, "Green" and Lead-free. 3. Halogen- and Antimony-free "Green” products are defined as those which contain <900ppm bromine, <900ppm chlorine (<1500ppm total Br + Cl) and <1000ppm antimony compounds. 4. For packaging details, go to our website at https://www.diodes.com/design/support/packaging/diodes-packaging/.
Marking Information
U-DFN2020-6 (SWP) (Type A) 2D9 = Product Type Marking Code Y = Year: 0~9 2D9 W = Week: A~Z: 1~26 week; a~z: 27~52 week; z represents YWX 52 and 53 week X = A~Z: Internal code ZXTP56060FDBQ 1 of 8 17 February 2020 Datasheet number: DS39605 Rev. 2 - 2
www.diodes.com
© Diodes Incorporated Document Outline Mechanical Data Description This bipolar junction transistors (BJT) is designed to meet the stringent requirements of automotive applications. Features BVCEO > -60V Application Matrix LED Lighting Power Management Characteristic Characteristic Marking Information 2D9 YWX 2D9 = Product Type Marking Code Y = Year: 0~9 W = Week: A~Z: 1~26 week; a~z: 27~52 week; z represents 52 and 53 week X = A~Z: Internal code Package Outline Dimensions Suggested Pad Layout
