Datasheet ICS-40638 (TDK) - 3
ПроизводительTDK
ОписаниеHigh AOP Analog MEMS Microphone with Differential Output
Страниц / Страница14 / 3 —   ICS‐40638. SPECIFICATIONS  . TABLE 1. ELECTRICAL CHARACTERISTICS . …
Формат / Размер файлаPDF / 391 Кб
  ICS‐40638. SPECIFICATIONS  . TABLE 1. ELECTRICAL CHARACTERISTICS . PARAMETER   . CONDITIONS . MIN . TYP . MAX . UNITS . NOTES
  ICS‐40638 SPECIFICATIONS   TABLE 1. ELECTRICAL CHARACTERISTICS  PARAMETER    CONDITIONS  MIN  TYP  MAX  UNITS  NOTES
30 предложений от 8 поставщиков
Устройство регулировки звука, МЭМС Микрофон, 1.52V to 3.63V, LGA, 5 вывод(-ов), -40 °C
ICS-40638
InvenSense
308 ₽
ICS-40638
TDK
от 401 ₽
ICS-40638
InvenSense
от 463 ₽
ICS-40638
    ICS‐40638
TA = 25°C, VDD = 1.52 to 3.63 V, unless otherwise noted. Typical specifications are not guaranteed.
PARAMETER    CONDITIONS  MIN  TYP  MAX  UNITS  NOTES  PERFORMANCE
Directionality    Omni      Output Polarity    Non‐Inverted      Sensitivity   1 kHz, 94 dB SPL, differential  −44  −43  −42  dBV    Signal‐to‐Noise Ratio (SNR)  20 kHz bandwidth, A‐weighted    63    dBA    Equivalent Input Noise (EIN)  20 kHz bandwidth, A‐weighted    31    dBA SPL    Derived from EIN and acoustic    Dynamic Range    107    dB  overload point  Total Harmonic Distortion (THD)  105 dB SPL    0.2    %    1 kHz, 100 mV p‐p sine wave  Power Supply Rejection Ratio (PSRR)    ‐81    dB    superimposed on VDD = 2.75 V  217 Hz, 100 mVp‐p square wave  Power Supply Rejection (PSR)    −111    dBV    superimposed on VDD = 2.75 V  Acoustic Overload Point  10% THD    138    dB SPL
POWER SUPPLY
Supply Voltage (VDD)  Standard mode  1.52    3.63  V    Supply Current (IS)  VDD = 1.8 V    170  190  µA
OUTPUT CHARACTERISTICS
Differential Output Impedance      355    Ω    Output Common Mode Voltage  OUTPUT+ and OUTPUT‐    1.0    V    Output Differential Offset  Between OUTPUT+ and OUTPUT−    10    mV      Startup Time  Output to within ±0.5 dB of stable    15  20  ms    sensitivity  Maximum Output Voltage  138 dB SPL input    1.0    V  rms    Noise Floor  20 Hz to 20 kHz, A‐weighted, rms    −106    dBV    Page 3 of 14  Document Number: DS‐000281  Revision: 1.1
