Datasheet ADCMP371-KGD (Analog Devices) - 3
ОписаниеGeneral Purpose Comparators
Страниц / Страница6 / 3 — Known Good Die. ADCMP371-KGD. SPECIFICATIONS. Table 1. Parameter. Min. …
Формат / Размер файлаPDF / 136 Кб
Known Good Die. ADCMP371-KGD. SPECIFICATIONS. Table 1. Parameter. Min. Typ. Max. Unit. Test Conditions/Comments
Known Good Die ADCMP371-KGD SPECIFICATIONS Table 1 Parameter Min Typ Max Unit Test Conditions/Comments
51 предложений от 20 поставщиков
Микросхема Компаратор, ANALOG DEVICES ADCMP371AKSZ-REEL7 Analog Comparator, Single, General Purpose, 1, 5µs, 2.25V to 5.5V, SC-70, 5Pins
ADCMP371AKSZ-REEL7
19 ₽
ADCMP371AKSZ-REEL7
155 ₽
727GS
ADCMP371AKSZ-REEL7
от 156 ₽
Hi-Tech Circuit Group
ADCMP371AKSZ-REEL7
VCC = full operating range, TA = −40°C to +85°C, unless otherwise noted.
Table 1. Parameter Min Typ Max Unit Test Conditions/Comments
SUPPLY VCC Operating Voltage Range 2.25 5.5 V Supply Current 4 7 µA COMMON-MODE INPUT RANGE 0 VCC V INPUT OFFSET VOLTAGE 9 mV VIN = VCC/2 INPUT OFFSET VOLTAGE AVERAGE DRIFT 5 µV/°C VCM = 0 V INPUT BIAS CURRENT 50 nA VIN = VCC/2 INPUT OFFSET CURRENT 150 nA VIN = VCC/2 OUT VOLTAGE LOW 0.4 V IN+ < IN−, ISINK = 1.2 mA OUT VOLTAGE HIGH 0.8 VCC V IN+ > IN−, ISOURCE = 500 µA Output Rise Time 30 ns COUT = 15 pF Output Fall Time 45 ns COUT = 15 pF TIMING Propagation Delay 5 µs Input overdrive = 10 mV 2 µs Input overdrive = 100 mV Rev. 0 | Page 3 of 6 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS OUTLINE DIMENSIONS DIE SPECIFICATIONS AND ASSEMBLY RECOMMENDATIONS ORDERING GUIDE
