Datasheet HMC675LP3E (Analog Devices) - 5
Описание10 GHz Latched Comparator with RSCML Output Stage
Страниц / Страница10 / 5 — HMC675LP3E. 10 GHz LATCHED COMPARATOR. WITH RSCML OUTPUT STAGE. …
Формат / Размер файлаPDF / 556 Кб
HMC675LP3E. 10 GHz LATCHED COMPARATOR. WITH RSCML OUTPUT STAGE. Operational Description
HMC675LP3E 10 GHz LATCHED COMPARATOR WITH RSCML OUTPUT STAGE Operational Description
IC COMPARATOR RSCML 16QFN. Comparator General Purpose 16-SMT (3x3). Linear - Comparators
HMC675LP3ETR
932 ₽
HMC675LP3ETR
Hittite
2 324 ₽
ЧипСити
HMC675LP3ETR
2 821 ₽
HMC675LP3ETR
HMC675LP3E
v02.0312
T The HMC675LP3E is a Latched Comparator with 10 GHz equivalent input bandwidth. The device is comprised of three M blocks: 1) An input amplifier, 2) A latch, and 3) An RSCML Output Buffer. The latching circuit is level sensitive, and consists of a single high-speed latch. The HMC675LP3E comparator supports 10 Gb/s operation. The minimum input data latching pulse width is 60 ps. S - S The HMC675LP3E operates in either Track (Transparent) Mode, where the output fol ows the logical value of the input, or R the Latch (Hold) Mode, where the output value is held to the logical value of the comparison result of the input just prior O to (LE - LE_bar) going HI. Track Mode operation is selected by either 1) (LE - LE_bar) LO, or 2) LE and LE_bar inputs AT floating. Latch Mode is selected by (LE - LE_bar) HI. The input impedance of the LE and LE_bar inputs is 8 k ohms, but R these inputs can be terminated with 50 ohm external resistors if desired. A When DC coupled, the clock inputs operate at an input common mode voltage of 2 V. In this case, any termination P resistors would ideal y be returned to 2 V. If the clock is AC coupled to the device, the input termination resistors can be returned to ground. OM C I F nf o or r p mati r o in cfe ur , d nish e e l d iv b e y r A y a nalo n g d t Devi o p ces i la s c bele o ieve rd d t e o rbs e : H acc iutrtatite e M and ic reli rao bl w e. a H v o e C wever o , nrp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Phoe n r O e: 7 n- 81-li 3 n 2 e a 9-4 t w 70 ww 0 • O . rdh e itt r o it nle i . n co e a m
5
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 p o plic ra a tio pp n S s u @ p h por ittti : Pte ho.c n om e: 1-800-ANALOG-D
