Datasheet ADCMP567 (Analog Devices) - 4
ОписаниеDual Ultrafast Voltage Comparator
Страниц / Страница14 / 4 — ADCMP567. Data Sheet. Parameter Symbol. Condition. Min. Typ. Max. Unit
ВерсияA
Формат / Размер файлаPDF / 167 Кб
ADCMP567 Data Sheet Parameter Symbol Condition Min Typ Max Unit
34 предложений от 17 поставщиков
IC COMP DUAL ULTRA-FAST 32LFCSP. Comparator with Latch Complementary, Differential, Open-Emitter, PECL 32-LFCSP-VQ (5x5). Linear - Comparators
ADCMP567BCPZ
963 ₽
EVAL-ADCMP567BCPZ
34 158 ₽
ЧипСити
EVAL-ADCMP567BCPZ
34 158 ₽
Hi-Tech Circuit Group
EVAL-ADCMP567BCPZ
AC PERFORMANCE (continued) Equivalent Input Rise Time Bandwidth BW 0 V to 1 V swing, 3500 5000 MHz 20% to 80%, 50 ps tR, tF Toggle Rate >50% output swing 5 Gbps Minimum Pulse Width PW tPD from 10 ns to 200 ps 200 ps < ±25 ps Unit to Unit Propagation Delay Skew ±10 ps POWER SUPPLY Positive Supply Current IV at +5.0 V 7 13 20 mA CC Negative Supply Current IV at −5.2 V 60 78 95 mA EE Logic Supply Current IV at 3.3 V, without load 8 13 18 mA DD Logic Supply Current IV at 3.3 V, with load 50 65 80 mA DD Positive Supply Voltage VCC Dual 4.75 5.0 5.25 V Negative Supply Voltage VEE Dual −4.96 −5.2 −5.45 V Logic Supply Voltage VDD Dual 2.5 3.3 5.0 V Power Dissipation Dual, without load 415 515 615 mW Power Dissipation Dual, with load 575 675 mW Power Supply Sensitivity—VCC PSSV 69 dB CC Power Supply Sensitivity—VEE PSSV 85 dB EE Power Supply Sensitivity—VDD PSSV 70 dB DD 1 Under no circumstances should the input voltages exceed the supply voltages. Rev. A | Page 4 of 14 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL CONSIDERATIONS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TIMING INFORMATION APPLICATIONS INFORMATION CLOCK TIMING RECOVERY OPTIMIZING HIGH SPEED PERFORMANCE COMPARATOR PROPAGATION DELAY DISPERSION COMPARATOR HYSTERESIS MINIMUM INPUT SLEW RATE REQUIREMENT TYPICAL APPLICATION CIRCUITS TYPICAL PERFORMANCE CHARACTERISTICS OUTLINE DIMENSIONS ORDERING GUIDE
