Datasheet ADM7160 (Analog Devices) - 7
Описание | Ultralow Noise, 200 mA, Linear Regulator |
Страниц / Страница | 24 / 7 — Data Sheet. ADM7160. TYPICAL PERFORMANCE CHARACTERISTICS. 100. VOUT = … |
Версия | A |
Формат / Размер файла | PDF / 677 Кб |
Язык документа | английский |
Data Sheet. ADM7160. TYPICAL PERFORMANCE CHARACTERISTICS. 100. VOUT = 3.3V V. OUT = 2.5V. OUT = 3.3V. OUT = 1.8V. NOISE FLOOR
53 предложений от 18 поставщиков Чип стабилизации напряжения, ANALOG DEVICES ADM7160AUJZ-2.5-R7 Fixed LDO Voltage Regulator, 2.2V to 5.5V In, 150mV Dropout, 2.5V/200mA Out, TSOT-5 |
| ADM7160AUJZ-2.5-R7 Analog Devices | от 22 ₽ | |
| ADM7160AUJZ-2.5-R7 Analog Devices | от 63 ₽ | |
| ADM7160AUJZ-2.5-R7 Analog Devices | от 134 ₽ | |
| ADM7160AUJZ-2.5-R7 Analog Devices | от 139 ₽ | |
Data Sheet ADM7160 TYPICAL PERFORMANCE CHARACTERISTICS
VIN = 2.9 V, VOUT = 2.5 V, ILOAD = 1 mA, CIN = COUT = 4.7 µF, TA = 25°C, unless otherwise noted.
1k 100 VOUT = 3.3V V V OUT = 2.5V OUT = 3.3V V V OUT = 1.8V OUT = 2.5V NOISE FLOOR VOUT = 1.8V 100 ) ) s m µV r 10 (nV/√Hz 10 D ISE ( NS O N 1 0.1 1
007
10 100 1k 10k 100k 1M
005
0.01 0.1 1 10 100 1000 FREQUENCY (Hz)
1334-
I
1334- 1
LOAD (mA)
1 Figure 4. Noise Spectral Density at Various Output Voltages, ILOAD = 10 mA Figure 7. RMS Noise vs. Load Current, 10 Hz to 100 kHz
008
006
1334-
I
1334- 1
LOAD (mA)
1 Figure 5. Noise Spectral Density at Various Output Voltages, ILOAD = 200 mA Figure 8. RMS Noise vs. Load Current, 10 Hz to 1 MHz
10k 1k z) √H V/ (n 100 SD N 10 1 0.1 1 10 100 1k
103
FREQUENCY (Hz)
1334- 1 Figure 6. Noise Spectral Density, 0.1 Hz to 1 kHz Rev. A | Page 7 of 24 Document Outline Features Applications Application Circuit General Description Table of Contents Revision History Specifications Input and Output Capacitors, Recommended Specifications Absolute Maximum Ratings Thermal Data Thermal Resistance ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Theory of Operation Enable Feature Soft Start Current-Limit and Thermal Overload Protection Applications Information Capacitor Selection Output Capacitor Input Bypass Capacitor Input and Output Capacitor Properties Thermal Considerations PCB Layout Considerations Typical Application Circuits Outline Dimensions Ordering Guide
