Линейка продуктов KEEN SIDE
Datasheet HMC976LP3E (Analog Devices) - 7
Описание400 mA Low Noise, High PSRR Linear Voltage Regulator
Страниц / Страница12 / 7 — HMC976LP3E. 400mA LOW NOISE, HIGH PSRR. LINEAR VOLTAGE REGULATOR. …
HMC976LP3E. 400mA LOW NOISE, HIGH PSRR. LINEAR VOLTAGE REGULATOR. Evaluation PCB. Table 6. Ordering Information
HMC976LP3E 400mA LOW NOISE, HIGH PSRR LINEAR VOLTAGE REGULATOR Evaluation PCB Table 6 Ordering Information
18 предложений от 11 поставщиков
Чип стабилизации напряжения, LDO Regulator Pos 1.8V to 5.1V/4.8V/5V 0.4A 16Pin QFN EP T/R
HMC976LP3ETR
378 ₽
HMC976LP3ETR
510 ₽
HMC976LP3ETR
879 ₽
Hi-Tech Circuit Group
HMC976LP3ETR
HMC976LP3E
v02.1112
T
M Item Contents Part Number Evaluation PCB HM976LP3E Evaluation PCB 131671-HMC976LP3E G - S IN
Table 7. List of Materials for Evaluation PCB 131671
N Item Contents IO J1 PCB Mount SMA connector IT J3 3 Pin Header D JP4, JP6, JP7, JP8, 2 Pin Header and Jumper N C10, C12, C21 4.7µF Capacitor 0603 Pkg. O C11 0.1µF Capacitor 0402 Pkg. R13 0.2 Ohm Resistor 0402 Pkg. R C R3 1 Ohm Resistor 0402 Pkg. E R8 100 kOhm Resistor 0402 Pkg. TP1, TP3 Test Point PC Compact Red W TP2 Test Point PC Compact Black O U1 HMC976LP3E 400mA Low Noise, High PSRR P Linear Voltage Regulator PCB 131669 Eval Board InfoFro ma r p tion rfiucre nis, d he e d lbiv y e An raly a og n Ded t viceo p s is la be clie o eved rtd o e b re sa: H ccur iattti e te M and re ilicarbloew . a Ho ve C wever, onro For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other poration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 7 978-250-3343 tel • 978-250-3373 fax • O rights of third parties that may result from its use. Specifications subject to change without notice. No rd P e h r O one n : 7-lin 81- e a 329-t w 47 w 0 w.h 0 • O it rd teite r o .nc li o n m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. e at www.analog.com Application S Trademarks and registered trademarks are the property of their respective owners. upport: apps@ A h p i p tliti c te ati .ocom n Support: Phone: 1-800-ANALOG-D
