Datasheet ADP130 (Analog Devices) - 4
Описание350 mA, Low VIN, Low Quiescent Current, CMOS Linear Regulator
Страниц / Страница20 / 4 — ADP130. Data Sheet. Parameter. Symbol Conditions. Min Typ Max Unit. INPUT …
ВерсияC
Формат / Размер файлаPDF / 409 Кб
ADP130. Data Sheet. Parameter. Symbol Conditions. Min Typ Max Unit. INPUT AND OUTPUT CAPACITOR: RECOMMENDED SPECIFICATIONS
ADP130 Data Sheet Parameter Symbol Conditions Min Typ Max Unit INPUT AND OUTPUT CAPACITOR: RECOMMENDED SPECIFICATIONS
36 предложений от 15 поставщиков
Чип стабилизации напряжения, 350mA, Low VIN, Low Quiescent Current, CMOS Linear Regulator with soft start LDO Regulator Pos 1.8V 0.35A 5Pin...
Зенер
Россия и страны ТС
ADP130AUJZ-1.8-R7
от 109 ₽
Эиком
ADP130AUJZ-1.8-R7
от 139 ₽
727GS
ADP130AUJZ-1.8-R7
1 571 ₽
ADP130AUJZ-1.8-R7
link to page 4
OUTPUT NOISE OUTNOISE 10 Hz to 100 kHz, VIN = 3.6 V, VOUT = 0.8 V 29 μV rms 10 Hz to 100 kHz, VIN = 3.6 V, VOUT = 1.2 V 38 μV rms 10 Hz to 100 kHz, VIN = 3.6 V, VOUT = 1.5 V 43 μV rms 10 Hz to 100 kHz, VIN = 3.6 V, VOUT = 2.5 V 61 μV rms 10 Hz to 100 kHz, VIN = 3.6 V, VOUT = 3.0 V 77 μV rms POWER SUPPLY REJECTION RATIO PSRR Modulated bias, 10 kHz, VOUT = 3.0 V, VIN = 3.6 V, 70 dB VBIAS = 5 V Modulated bias, 100 kHz, VOUT = 3.0 V, VIN = 3.6 V, 53 dB VBIAS = 5 V Modulated VIN, 10 kHz, VOUT = 1.2 V, VIN = VOUT + 1 V, 70 dB VBIAS = 5 V Modulated VIN, 100 kHz, VOUT = 1.2 V, VIN = VOUT + 1 V, 54 dB VBIAS = 5 V Modulated VIN, 10 kHz, VOUT = 0.8 V, VIN = VOUT + 1 V, 70 dB VBIAS = 5 V Modulated VIN, 100 kHz, VOUT = 0.8 V, VIN = VOUT + 1 V, 55 dB VBIAS = 5 V 1 IVIN = IGND − IBIAS, where IGND is the current flowing from the GND pin. 2 Based on an endpoint calculation using 1 mA and 350 mA loads. 3 Dropout voltage is defined as the input-to-output voltage differential when the input voltage is set to the nominal output voltage. This applies only for output voltages above 1.3 V. 4 Start-up time is defined as the time from the rising edge of EN to VOUT being at 90% of its nominal value. 5 Current limit threshold is defined as the current at which the output voltage drops to 90% of the specified typical value. For example, the current limit for a 2.0 V output voltage is defined as the current that causes the output voltage to drop to 90% of 2.0 V, or 1.8 V.
INPUT AND OUTPUT CAPACITOR: RECOMMENDED SPECIFICATIONS Table 2. Parameter Symbol Conditions Min Typ Max Unit
MINIMUM INPUT AND OUTPUT CAPACITANCE1 CMIN TA = −40°C to +125°C 0.70 1 μF CAPACITOR ESR RESR TA = −40°C to +125°C 0.001 1 Ω 1 The minimum input and output capacitance should be >0.70 μF over the full range of operating conditions. The full range of operating conditions in the application must be considered during device selection to ensure that the minimum capacitance specification is met. X7R and X5R type capacitors are recommended. Y5V and Z5U capacitors are not recommended for use with any LDO. Rev. C | Page 4 of 20 Document Outline Features Applications Typical Application Circuits General Description Table of Contents Revision History Specifications Input and Output Capacitor: Recommended Specifications Absolute Maximum Ratings Thermal Data Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Applications Information Capacitor Selection Output Capacitor Input Bypass Capacitor Bias Capacitor Input, Bias, and Output Capacitor Properties Undervoltage Lockout Enable Feature Current Limit and Thermal Overload Protection Thermal Considerations Junction Temperature Calculations PCB Layout Considerations Outline Dimensions Ordering Guide
