Datasheet SiRA99DP (Vishay) - 5
ПроизводительVishay
ОписаниеP-Channel 30 V (D-S) MOSFET
Страниц / Страница9 / 5 — SiRA99DP. TYPICAL CHARACTERISTICS. Current Derating a. Power, …
Формат / Размер файлаPDF / 251 Кб
SiRA99DP. TYPICAL CHARACTERISTICS. Current Derating a. Power, Junction-to-Case. Power, Junction-to-Ambient. Note
SiRA99DP TYPICAL CHARACTERISTICS Current Derating a Power, Junction-to-Case Power, Junction-to-Ambient Note
33 предложений от 10 поставщиков
, Trans MOSFET P-CH 30V 47.9A 8-Pin PowerPAK SO EP T/R
SIRA99DP-T1-GE3
117 ₽
Эиком
SIRA99DP-T1-GE3
от 305 ₽
SIRA99DP-T1-GE3
от 308 ₽
Hi-Tech Circuit Group
SIRA99DP-T1-GE3
SiRA99DP
www.vishay.com Vishay Siliconix
(25 °C, unless otherwise noted) Axis Title 250 10000 200 ) 1000 150 rrent (A ne ne ine u C n 1st li 2nd li 2nd l 100 rai D 100 - I D 50 0 10 0 25 50 75 100 125 150 T - Case Temperature (°C) C
Current Derating a
Axis Title Axis Title 125 10000 3.0 10000 100 2.4 1000 ) 1000 ) 75 (W 1.8 (W ne ne ine ne er ne ine er ow 1st li ow P 2nd li 2nd l 1st li P 2nd li 50 2nd l 1.2 - - P 100 P 100 25 0.6 0 10 0 10 0 25 50 75 100 125 150 0 25 50 75 100 125 150 T - Case Temperature (°C) T - Ambient Temperature (°C) C A
a. The power dissipation PD is based on TJ max. = 150 °C, using junction-to-case thermal resistance, and is more useful in settling the upper dissipation limit for cases where additional heatsinking is used. It is used to determine the current rating, when this rating falls below the package limit S19-0115-Rev. A, 04-Feb-2019
5
Document Number: 71023 For technical questions, contact: pmostechsupport@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
