Datasheet AD534 (Analog Devices) - 6
ОписаниеInternally Trimmed Precision IC Multiplier
Страниц / Страница20 / 6 — AD534. Data Sheet. AD534S. AD534T. Parameter. Min. Typ. Max. Unit
ВерсияD
Формат / Размер файлаPDF / 334 Кб
AD534 Data Sheet AD534S AD534T Parameter Min Typ Max Unit
18 предложений от 18 поставщиков
Интегральные микросхемы Линейные микросхемы - Аналоговые мультиплексоры, Делители
Зенер
Россия и страны ТС
AD534LD
40 531 ₽
МосЧип
AD534LD
Hi-Tech Circuit Group
AD534LD
AD534LD
link to page 1 link to page 6 link to page 6 link to page 6 link to page 6 link to page 6 link to page 6
AD534 Data Sheet AD534S AD534T Parameter Min Typ Max Min Typ Max Unit
DIVIDER PERFORMANCE Transfer Function (X1 > X2) (Z  Z ) (Z  Z ) 2 1 10 V Y 2 1 10 V Y 1 (X  X ) 1 (X  X ) 1 2 1 2 Total Error1 X = 10 V, −10 V ≤ Z ≤ +10 V ±0.75 ±0.35 % X = 1 V, −1 V ≤ Z ≤ +1 V ±2.0 ±1.0 % 0.1 V ≤ X ≤ 10 V, −10 V ≤ Z ≤ +10 V ±2.5 ±1.0 % SQUARER PERFORMANCE Transfer Function (X  X )2 (X  X )2 1 2 Z 1 2 Z 2 10 V 2 10 V Total Error (−10 V ≤ X ≤ +10 V) ±0.6 ±0.3 % SQUARE-ROOTER PERFORMANCE Transfer Function (Z1 ≤ Z2) √(10 V(Z2 – Z1)) + X2 √(10 V(Z2 – Z1)) + X2 Total Error1 (1 V ≤ Z ≤ 10 V) ±1.0 ±0.5 % POWER SUPPLY SPECIFICATIONS Supply Voltage Rated Performance ±15 ±15 V Operating ±8 ±222 ±8 ±222 V Supply Current Quiescent 4 62 4 62 mA 1 Specifications given are percent of full scale, ±10 V (that is, 0.01% = 1 mV). 2 Tested on all production units at final electrical test. Results from those tests are used to calculate outgoing quality levels. 3 Can be reduced down to 3 V using external resistor between –VS and SF. 4 Irreducible component due to nonlinearity: excludes effect of offsets. 5 Using external resistor adjusted to give SF = 3 V. 6 See Figure 1 for definition of sections. Rev. D | Page 6 of 20 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Functional Description Provides Gain with Low Noise Operation as a Multiplier Operation as a Squarer Operation as a Divider Operation as a Square Rooter Unprecedented Flexibility Applications Information Outline Dimensions Ordering Guide
