Datasheet AD8429 (Analog Devices) - 5
Описание1 nV/√Hz Low Noise Instrumentation Amplifier
Страниц / Страница20 / 5 — Data Sheet. AD8429. A Grade. B Grade. Parameter. Test …
ВерсияA
Формат / Размер файлаPDF / 668 Кб
Data Sheet. AD8429. A Grade. B Grade. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit
Data Sheet AD8429 A Grade B Grade Parameter Test Conditions/Comments Min Typ Max Unit
25 предложений от 11 поставщиков
ANALOG DEVICES - AD8429BRZ-R7 - Instrument Amplifier, 1 Amplifier, 50 µV, 22 V/µs, 15 MHz, ± 4V to ± 18V, SOIC...
AD8429BRZ-R7
от 278 ₽
AD8429BRZ-R7
486 ₽
AD8429BRZ-R7
721 ₽
727GS
AD8429BRZ-R7
от 4 304 ₽
link to page 15 link to page 16
Data Sheet AD8429 A Grade B Grade Parameter Test Conditions/Comments Min Typ Max Min Typ Max Unit
POWER SUPPLY Operating Range ±4 ±18 ±4 ±18 V Quiescent Current 6.7 7 6.7 7 mA T = 125°C 9 9 mA TEMPERATURE RANGE For Specified Performance −40 +125 −40 +125 °C 1 Total voltage noise = √(e 2 2 ni + (eno/G)2 + eRG ). See the Theory of Operation section for more information. 2 Total RTI VOS = (VOSI) + (VOSO/G). 3 These specifications do not include the tolerance of the external gain setting resistor, RG. For G > 1, add RG errors to the specifications given in this table. 4 Differential and common-mode input impedance can be calculated from the pin impedance: ZDIFF = 2(ZPIN); ZCM = ZPIN/2. 5 Input voltage range of the AD8429 input stage only. The input range can depend on the common-mode voltage, differential voltage, gain, and reference voltage. See the Input Voltage Range section for more details. Rev. A | Page 5 of 20 Document Outline FEATURES APPLICATIONS PIN CONNECTION DIAGRAM GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION ARCHITECTURE RG Power Dissipation REFERENCE TERMINAL INPUT VOLTAGE RANGE LAYOUT Common-Mode Rejection Ratio over Frequency Power Supplies and Grounding Reference Pin INPUT BIAS CURRENT RETURN PATH INPUT PROTECTION Input Voltages Beyond the Rails Large Differential Input Voltage at High Gain IMAX RADIO FREQUENCY INTERFERENCE (RFI) CALCULATING THE NOISE OF THE INPUT STAGE Source Resistance Noise Voltage Noise of the Instrumentation Amplifier Current Noise of the Instrumentation Amplifier Total Noise Density Calculation OUTLINE DIMENSIONS ORDERING GUIDE
