Datasheet AD8295 (Analog Devices) - 26
ОписаниеPrecision Instrumentation Amplifier with Signal Processing Amplifiers
Страниц / Страница28 / 26 — AD8295. OUTLINE DIMENSIONS. 4.00. 0.60 MAX. BSC SQ. 0.65. PIN 1. 3.75. …
ВерсияA
Формат / Размер файлаPDF / 684 Кб
AD8295. OUTLINE DIMENSIONS. 4.00. 0.60 MAX. BSC SQ. 0.65. PIN 1. 3.75. BSC. INDICATOR. BCS SQ. 1.95 REF. 0.75. TOP VIEW. 0.60. BOTTOM VIEW. 0.50. 12° MAX
AD8295 OUTLINE DIMENSIONS 4.00 0.60 MAX BSC SQ 0.65 PIN 1 3.75 BSC INDICATOR BCS SQ 1.95 REF 0.75 TOP VIEW 0.60 BOTTOM VIEW 0.50 12° MAX
25 предложений от 14 поставщиков
Микросхема Усилитель прибора, ANALOG DEVICES AD8295BCPZ-WP Instrument Amplifier, 2 Amplifier, 60µV, 2V/µs, 1.2MHz, ± 2.3V to ± 18V, LFCSP
AD8295BCPZ-WP
498 ₽
T-electron
AD8295BCPZ-WP
802 ₽
727GS
AD8295BCPZ-WP
от 2 988 ₽
AD8295BCPZ-WP
link to page 26
AD8295 OUTLINE DIMENSIONS 4.00 0.60 MAX BSC SQ 0.60 MAX 13 16 12 1 0.65 PIN 1 3.75 BSC INDICATOR BCS SQ 1.95 REF SQ 9 4 8 5 0.75 TOP VIEW 0.60 BOTTOM VIEW 0.50 12° MAX 0.80 MAX 1.00 0.65 TYP 0.85 0.05 MAX 0.80 0.02 NOM COPLANARITY SEATING 0.35 0.08 PLANE 0.30 0.20 REF 0.25 B COMPLIANT TO JEDEC STANDARDS MO-263-VBBC 062309-
Figure 72. 16-Lead Lead Frame Chip Scale Package [LFCSP_VQ] 4 mm × 4 mm Body, Very Thin Quad, with Hidden Paddle (CP-16-19) Dimensions shown in millimeters
ORDERING GUIDE Model Temperature Range Package Description Package Option
AD8295ACPZ-R71 −40°C to +85°C 16-Lead LFCSP_VQ, 7-Inch Tape and Reel CP-16-19 AD8295ACPZ-RL1 −40°C to +85°C 16-Lead LFCSP_VQ, 13-Inch Tape and Reel CP-16-19 AD8295ACPZ-WP1 −40°C to +85°C 16-Lead LFCSP_VQ, Waffle Pack CP-16-19 AD8295BCPZ-R71 −40°C to +85°C 16-Lead LFCSP_VQ, 7-Inch Tape and Reel CP-16-19 AD8295BCPZ-RL1 −40°C to +85°C 16-Lead LFCSP_VQ, 13-Inch Tape and Reel CP-16-19 AD8295BCPZ-WP1 −40°C to +85°C 16-Lead LFCSP_VQ, Waffle Pack CP-16-19 1 Z = RoHS Compliant Part. Rev. A | Page 26 of 28 Document Outline FEATURES APPLICATIONS CONNECTION DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS INSTRUMENTATION AMPLIFIER SPECIFICATIONS, SINGLE-ENDED AND DIFFERENTIAL OUTPUT CONFIGURATIONS OP AMP SPECIFICATIONS INTERNAL RESISTOR NETWORK POWER AND TEMPERATURE SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL CHARACTERISTICS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS IN-AMP OP AMPS SYSTEM THEORY OF OPERATION UNCOMMITTED OP AMPS INSTRUMENTATION AMPLIFIER Gain Selection Common-Mode Input Voltage Range Reference Terminal LAYOUT Routing and Vias Common-Mode Rejection over Frequency Unused Op Amps Reference Power Supplies INPUT PROTECTION INPUT BIAS CURRENT RETURN PATH RF INTERFERENCE DIFFERENTIAL OUTPUT APPLICATIONS INFORMATION CREATING A REFERENCE VOLTAGE AT MIDSCALE HIGH ACCURACY G = −1 CONFIGURATION WITH LOW-PASS FILTER TWO-POLE SALLEN-KEY FILTER AC-COUPLED INSTRUMENTATION AMPLIFIER DRIVING DIFFERENTIAL ADCs OUTLINE DIMENSIONS ORDERING GUIDE
