Datasheet AD8253 (Analog Devices) - 4
Описание10 MHz, G = 1, 10, 100, 1000 iCMOS Programmable Gain Instrumentation Amplifier
Страниц / Страница24 / 4 — AD8253. Data Sheet. Parameter. Conditions. Min. Typ. Max. Unit
ВерсияB
Формат / Размер файлаPDF / 426 Кб
AD8253 Data Sheet Parameter Conditions Min Typ Max Unit
48 предложений от 19 поставщиков
MSOP10;Инструментальный усилитель с цифровым программируемым коэффициентом усиления, входным импедансом 1 ГОм, низким выходным шумом и низким уровнем искажений
AD8253ARMZ-R7
398 ₽
AD8253ARMZ-R7
от 809 ₽
AD8253ARMZ-R7
от 1 534 ₽
МосЧип
AD8253ARMZ-R7
link to page 5 link to page 5 link to page 5 link to page 5
Settling Time 0.001% ΔOUT = 10 V step G = 1 780 ns G = 10 880 ns G =100 1.8 μs G = 1000 1.8 μs Slew Rate G = 1 20 V/μs G = 10 20 V/μs G = 100 12 V/μs G = 1000 2 V/μs Total Harmonic Distortion + Noise f = 1 kHz, RL = 10 kΩ, ±10 V, −110 dB G = 1, 10 Hz to 22 kHz band- pass filter GAIN Gain Range G = 1, 10, 100, 1000 1 1000 V/V Gain Error OUT = ±10 V G = 1 0.03 % G = 10, 100, 1000 0.04 % Gain Nonlinearity OUT = −10 V to +10 V G = 1 RL = 10 kΩ, 2 kΩ, 600 Ω 5 ppm G = 10 RL = 10 kΩ, 2 kΩ, 600 Ω 3 ppm G = 100 RL = 10 kΩ, 2 kΩ, 600 Ω 18 ppm G = 1000 RL = 10 kΩ, 2 kΩ, 600 Ω 110 ppm Gain vs. Temperature All gains 3 10 ppm/°C INPUT Input Impedance Differential 4||1.25 GΩpF Common Mode 1||5 GΩpF Input Operating Voltage Range VS = ±5 V to ±15 V −VS + 1 +VS − 1.5 V Over Temperature3 T = −40°C to +85°C −VS + 1.2 +VS − 1.7 V OUTPUT Output Swing −13.7 +13.6 V Over Temperature4 T = −40°C to +85°C −13.7 +13.6 V Short-Circuit Current 37 mA REFERENCE INPUT RIN 20 kΩ IIN +IN, −IN, REF = 0 1 μA Voltage Range −VS +VS V Gain to Output 1 ± 0.0001 V/V DIGITAL LOGIC Digital Ground Voltage, DGND Referred to GND −VS + 4.25 0 +VS − 2.7 V Digital Input Voltage Low Referred to GND DGND 2.1 V Digital Input Voltage High Referred to GND 2.8 +VS V Digital Input Current 1 μA Gain Switching Time5 325 ns tSU See Figure 3 timing diagram 15 ns tHD 30 ns t WR -LOW 20 ns t WR -HIGH 15 ns Rev. B | Page 4 of 24 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING DIAGRAM ABSOLUTE MAXIMUM RATINGS MAXIMUM POWER DISSIPATION ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION GAIN SELECTION Transparent Gain Mode Latched Gain Mode Timing for Latched Gain Mode POWER SUPPLY REGULATION AND BYPASSING INPUT BIAS CURRENT RETURN PATH INPUT PROTECTION REFERENCE TERMINAL COMMON-MODE INPUT VOLTAGE RANGE LAYOUT Grounding Coupling Noise Common-Mode Rejection RF INTERFERENCE DRIVING AN ANALOG-TO-DIGITAL CONVERTER APPLICATIONS INFORMATION DIFFERENTIAL OUTPUT SETTING GAINS WITH A MICROCONTROLLER DATA ACQUISITION OUTLINE DIMENSIONS ORDERING GUIDE
