Datasheet AD627 (Analog Devices) - 8
ОписаниеMicropower, Single and Dual Supply R/R Instrumentation Amplifier
Страниц / Страница24 / 8 — AD627. Data Sheet. PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS. –IN. …
ВерсияE
Формат / Размер файлаPDF / 968 Кб
AD627. Data Sheet. PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS. –IN. +VS. TOP VIEW. +IN. OUTPUT. (Not to Scale). REF
AD627 Data Sheet PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS –IN +VS TOP VIEW +IN OUTPUT (Not to Scale) REF
41 предложений от 22 поставщиков
Малопотребляющий Rail-to-Rail инструментальный усилитель с однополярным и биполярным питанием
Контест
AD627ARZ-R7
504 ₽
Элевика
AD627ARZ-R7
526 ₽
Триема
AD627ARZ-R7
564 ₽
AD627ARZ-R7
AD627 Data Sheet PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS RG 1 8 RG R 1 8 G RG –IN 2 AD627 7 +VS –IN 2 AD627 7 +V TOP VIEW S +IN 3 6 OUTPUT TOP VIEW (Not to Scale)
051
+IN 3 6 (Not to Scale) OUTPUT –V
052
S 4 5 REF –V 4 5 REF
00782-
S
00782- Figure 3. 8-Lead PDIP Pin Configuration Figure 4. 8-Lead SOIC_N Pin Configuration
Table 5. Pin Function Descriptions Pin No. Mnemonic Description
1 RG External Gain Setting Resistor. Place gain setting resistor across RG pins to set the gain. 2 −IN Negative Input. 3 +IN Positive Input. 4 −VS Negative Voltage Supply Pin. 5 REF Reference Pin. Drive with low impedance voltage source to level shift the output voltage. 6 OUTPUT Output Voltage. 7 +VS Positive Supply Voltage. 8 RG External Gain Setting Resistor. Place gain setting resistor across RG pins to set the gain. Rev. E | Page 8 of 24 Document Outline Features Applications Functional Block Diagram General Description Table of Contents Revision History Specifications Single Supply Dual Supply Dual and Single Supplies Absolute Maximum Ratings ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Theory of Operation Using the AD627 Basic Connections Setting the Gain Reference Terminal Input Range Limitations in Single-Supply Applications Output Buffering Input and Output Offset Errors Make vs. Buy: A Typical Application Error Budget Errors Due to AC CMRR Ground Returns for Input Bias Currents Layout and Grounding Input Protection RF Interference Applications Circuits Classic Bridge Circuit 4 mA to 20 mA Single-Supply Receiver Thermocouple Amplifier Outline Dimensions Ordering Guide
