Datasheet EPC2207 (Efficient Power Conversion) - 5
ПроизводительEfficient Power Conversion
ОписаниеEnhancement-Mode Power Transistor
Страниц / Страница6 / 5 — eGaN® FET DATASHEET. TAPE AND REEL CONFIGURATION. Z Z. YYY. 2207. DIM. …
eGaN® FET DATASHEET. TAPE AND REEL CONFIGURATION. Z Z. YYY. 2207. DIM. Dimension (mm). EPC2207 (Note 1) Target MIN. MAX. DIE MARKINGS
eGaN® FET DATASHEET TAPE AND REEL CONFIGURATION Z Z YYY 2207 DIM Dimension (mm) EPC2207 (Note 1) Target MIN MAX DIE MARKINGS
17 предложений от 6 поставщиков
Транзисторы - FETs
EPC2207
от 138 ₽
Эиком
EPC2207
от 195 ₽
Элитан
EPC2207
197 ₽
EPC2207
260 ₽
eGaN® FET DATASHEET
EPC2207
TAPE AND REEL CONFIGURATION e f
4 mm pitch, 8 mm wide tape on 7” reel Loaded Tape Feed Direction
d g
7” inch reel Die orientation
b
dot
Z Z ZZ c Y YYY
Gate solder bar
a
is under this
2207
corner Die is placed into pocket
h
solder bump side down
DIM Dimension (mm)
(face side down)
EPC2207 (Note 1) Target MIN MAX a
8.00 7.90 8.30
b
1.75 1.65 1.85
c
(Note 2) 3.50 3.45 3.55
d
4.00 3.90 4.10
e
4.00 3.90 4.10 Note 1: MSL 1 (moisture sensitivity level 1) classified according to IPC/
f
(Note 2) 2.00 1.95 2.05 JEDEC industry standard.
g
1.50 1.50 1.60 Note 2: Pocket position is relative to the sprocket hole measured as
h
1.00 1.00 1.25 true position of the pocket, not the pocket hole.
DIE MARKINGS 2207 YYYY Laser Markings
Die orientation dot
Part ZZZZ Number Part # Lot_Date Code Lot_Date Code Marking Line 1 Marking Line 2 Marking Line 3
Gate Pad bump is EPC2207 2207 YYYY ZZZZ under this corner
DIE OUTLINE
Solder Bump View
Micrometers
A
DIM MIN Nominal MAX A
2770 2800 2830
2
h
B
895 925 955
c
535 d j
3 4 5
c
6
B
d
775
e
600
1
g
f
250
g
250 f e
h
300
j
500 Side View ± -25 518 638
Pad 1 is Gate; Pads 2 ,4, 6 are Source; Pads 3, 5 are Drain
Seating plane 120 ± 12 EPC – POWER CONVERSION TECHNOLOGY LEADER | EPC-CO.COM | ©2020 | | 5
