Product Flyer MLX81116 (Melexis) - 2
ПроизводительMelexis
ОписаниеMulti-Channel RGB-LED Driver
Страниц / Страница2 / 2 — APPLICATION VISUAL. BLOCK DIAGRAM. GND. MLX81116. VIO. Voltage Regulator. …
Формат / Размер файлаPDF / 401 Кб
APPLICATION VISUAL. BLOCK DIAGRAM. GND. MLX81116. VIO. Voltage Regulator. HSW1. Multiplex. Control. HSW0. HSW2. HC0. LC6. RGB. LED 5. LED 6. 16-bit. LC7
APPLICATION VISUAL BLOCK DIAGRAM GND MLX81116 VIO Voltage Regulator HSW1 Multiplex Control HSW0 HSW2 HC0 LC6 RGB LED 5 LED 6 16-bit LC7
APPLICATION VISUAL
Discover the cockpit of the future with our MLX81116 enabling an (RGB-)LED light bar to communicate through smart lighting.
BLOCK DIAGRAM VS GND MLX81116 VS VIO VS Voltage Regulator HSW1 VS Multiplex Multiplex VS Control Control HSW0 HSW2 VS HC0 LC6 VS RGB RGB LED 5 LED 6 16-bit LC7 HC1 PWM VS 16-bit MCU PWM LC8 HC2 RGB LED 4 UART ADC/ Diagnosis LC0 LC3 RGB LED 1 RGB RGB RGB LED 3 CAN-FD LED 3 LED 4 LC1 PHY LC4 16-bit 16-bit PWM PWM LC2 LC5 AA COM_P COM_N AIN AOUT
0 The above information is “as is” and believed to be correct and accurate. Melexis disclaims any and all liability in connection with or arising out of the furnishing, application or use of the information or products; any and all liability, including without limitation, special, consequential or incidental damages; and any and all warranties, express, statutory, implied, or by description, including warranties of fitness for particular purpose, non-infringement and merchantability. Melexis reserves the right to change it at any time and without notice. Users should obtain the latest version of the information to verify it is current. Users must further determine the suitability of a product for its application, including the level of reliability required and determine whether it is fit for a particular purpose. Export control regulations may apply and export might require a prior authorization from competent authorities. Melexis’ products are intended for use in normal commercial applications. Unless otherwise agreed upon in writing, the products are not designed, authorized or warranted to be suitable in applications requiring extended temperature range and/or unusual environmental V1/25-08-2 requirements. High reliability applications, such as medical life-support or life-sustaining equipment are specifically not recommended by Melexis. Melexis’ products are sold under the Melexis’ Terms of Sale, which can be found at https://www.melexis.com/en/legal/terms-and-conditions.
