Datasheet MOC205M, MOC206M, MOC207M, MOC211M, MOC212M, MOC213M, MOC216M, MOC217M (ON Semiconductor) - 2
ПроизводительON Semiconductor
Описание8-pin SOIC Single-Channel Phototransistor Output
Страниц / Страница12 / 2 — MOC205M, MOC206M, MOC207M,. MOC211M, MOC212M, MOC213M, MOC216M, MOC217M. …
ВерсияA
Формат / Размер файлаPDF / 342 Кб
MOC205M, MOC206M, MOC207M,. MOC211M, MOC212M, MOC213M, MOC216M, MOC217M. 8-pin SOIC Single-Channel Phototransistor Output
MOC205M, MOC206M, MOC207M, MOC211M, MOC212M, MOC213M, MOC216M, MOC217M 8-pin SOIC Single-Channel Phototransistor Output
26 предложений от 14 поставщиков
Оптопара/ оптоизолятор, 8Pin SOIC Single-Channel Phototransistor Output Optocoupler
MOC211M
8.76 ₽
MOC211M
Fairchild
46 ₽
MOC211M
от 62 ₽
MOC211M RL
Optocoupler
Features Description • Closely Matched Current Transfer Ratios
• Minimum BVCEO of 70 V Guaranteed
– MOC205M, MOC206M, MOC207M
• Minimum BVCEO of 30 V Guaranteed
– MOC211M, MOC212M, MOC213M, MOC216M,
MOC217M
• Low LED Input Current Required for Easier Logic
Interfacing
– MOC216M, MOC217M
• Convenient Plastic SOIC-8 Surface Mountable
Package Style, with 0.050" Lead Spacing
• Safety and Regulatory Approvals:
– UL1577, 2,500 VACRMS for 1 Minute
– DIN-EN/IEC60747-5-5, 565 V Peak Working
Insulation Voltage These devices consist of a gallium arsenide infrared
emitting diode optically coupled to a monolithic silicon
phototransistor detector, in a surface mountable, small
outline, plastic package. They are ideally suited for
high-density applications, and eliminate the need for
through-the-board mounting. Applications
• Feedback Control Circuits
• Interfacing and Coupling Systems of Different
Potentials and Impedances
• General Purpose Switching Circuits
• Monitor and Detection Circuits Schematic Package Outline ANODE 1 8 N/C CATHODE 2 7 BASE Figure 2. Package Outline
N/C 3 6 COLLECTOR N/C 4 5 EMITTER Figure 1. Schematic
©2005 Fairchild Semiconductor Corporation
MOC20xM, MOC21xM Rev. 1.5 www.fairchildsemi.com MOC20xM, MOC21xM — 8-pin SOIC Single-Channel Phototransistor Output Optocoupler August 2015
