Datasheet IR11-21C (Everlight) - 6
ПроизводительEverlight
Описание1206 Package Chip Infrared LED With Inner Lens
Страниц / Страница9 / 6 — IR11-21C. Precautions For Use
Формат / Размер файлаPDF / 219 Кб
IR11-21C Precautions For Use
29 предложений от 18 поставщиков
Оптоэлектроника Излучатели инфракрасные, ультрафиолетовые и видимого диапазона
Эиком
IR11-21C/TR8
Everlight
от 13 ₽
IR11-21C/TR8
Everlight
от 21 ₽
Hi-Tech Circuit Group
IR11-21C/TR8
Everlight
LifeElectronics
IR11-21C-TR8
Everlight
1. Over-current-proof Customer must apply resistors for protection , otherwise slight voltage shift will cause big current change ( Burn out will happen ). 2. Storage 2.1 Do not open moisture proof bag before the products are ready to use. 2.2 Before opening the package, the LEDs should be kept at 30℃ or less and 90%RH or less. 2.3 The LEDs should be used within a year. 2.4 After opening the package, the LEDs should be kept at 30℃ or less and 70%RH or less. 2.5 The LEDs should be used within 168 hours (7 days) after opening the package. 2.6 If the moisture absorbent material (silica gel) has faded away or the LEDs have exceeded the storage time, baking treatment should be performed using the following conditions. Baking treatment : 60±5℃ for 24 hours. 3. Soldering Condition 3.1 Pb-free solder temperature profile 3.2 Reflow soldering should not be done more than two times. 3.3 When soldering, do not put stress on the LEDs during heating. 3.4 After soldering, do not warp the circuit board. Everlight Electronics Co., Ltd. http:\\www.everlight.com Rev 2.2 Page: 6 of 9 Device No:DIR-011-062 Prepared date:07-22-2004 Prepared by:Jaine Tsai
