Datasheet PD15-22C (Everlight) - 6
ПроизводительEverlight
ОписаниеSilicon PIN Photodiode
Страниц / Страница9 / 6 — PD15-22C. Precautions For Use
Формат / Размер файлаPDF / 163 Кб
PD15-22C Precautions For Use
29 предложений от 17 поставщиков
Сенсоры, Датчики Оптические датчики - Фотодиоды
PD15-22C/TR8
Everlight
от 4.75 ₽
PD15-22C/L1/TR8
Everlight
МосЧип
PD15-22C/L3/TR8
Everlight
EL-PD15-22C
Everlight
1. Over-current-proof Customer must apply resistors for protection , otherwise slight voltage shift will cause big current change ( Burn out will happen ). 2. Storage 2.1 Do not open moisture proof bag before the products are ready to use. 2.2 Before opening the package, the LEDs should be kept at 30℃ or less and 90%RH or less. 2.3 The LEDs should be used within a year. 2.4 After opening the package, the LEDs should be kept at 30℃ or less and 70%RH or less. 2.5 The LEDs should be used within 168 hours (7 days) after opening the package. 2.6 If the moisture absorbent material (silica gel) has faded away or the LEDs have exceeded the storage time, baking treatment should be performed using the following conditions. Baking treatment : 60±5℃ for 24 hours. 3. Soldering Condition 3.1 Pb-free solder temperature profile 3.2 Reflow soldering should not be done more than two times. 3.3 When soldering, do not put stress on the LEDs during heating. 3.4 After soldering, do not warp the circuit board. Everlight Electronics Co., Ltd. http:\\www.everlight.com Rev 3 Page: 6 of 9 Device No:DPD-152-013 Prepared date:07-20-2005 Prepared by:David Huang
