Datasheet MAX4230, MAX4231, MAX4232, MAX4233, MAX4234 (Maxim) - 3
ПроизводительMaxim
ОписаниеHigh-Output-Drive, 10MHz, 10V/µs, Rail-to-Rail I/O Op Amps with Shutdown in SC70
Страниц / Страница15 / 3 — DC Electrical Characteristics (continued). TA = +25°C. PARAMETER. SYMBOL. …
Формат / Размер файлаPDF / 1.9 Мб
DC Electrical Characteristics (continued). TA = +25°C. PARAMETER. SYMBOL. CONDITIONS. MIN. TYP. MAX. UNITS. DC Electrical Characteristics
DC Electrical Characteristics (continued) TA = +25°C PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS DC Electrical Characteristics
33 предложений от 21 поставщиков
MAX4232AKA/V+T
63 ₽
Microfind
MAX4232AKA+T
Maxim
100 ₽
Элитан
MAX4232AKA/V+
179 ₽
ТаймЧипс
MAX4232AKA-T
Maxim
MAX4230–MAX4234 High-Output-Drive, 10MHz, 10V/μs, Rail-to-Rail I/O Op Amps with Shutdown in SC70
(VDD = 2.7V, VSS = 0V, VCM = VDD/2, VOUT = (VDD/2), RL = ∞ connected to (VDD/2), VSHDN = VDD,
TA = +25°C
, unless otherwise noted.) (Note 2)
Output Source/Sink VDD = 2.7V, VIN = ±100mV 70 Current IOUT mA VDD = 5V, VIN = ±100mV 200 V I DD - VOH 128 200 L = 10mA VDD = 2.7V V Output Voltage OL - VSS 112 175 mV V I DD - VOH 240 320 L = 30mA VDD = 5V VOL - VSS 224 300 Quiescent Supply Current VDD = 5.5V, VCM = VDD/2 1.2 2.3 (per Amplifier) IDD mA VDD = 2.7V, VCM = VDD/2 1.1 2.0 Shutdown Supply Current VSHDN = 0V, VDD = 5.5V 0.5 1 (per Amplifier) (Note 3) IDD(SHDN) R µA L = ∞ VDD = 2.7V 0.1 1 SHDN Logic Threshold VIL Shutdown mode 0.8 (Note 3) V VIH Normal mode VDD x 0.57 SHDN Input Bias Current VSS < VSHDN < VDD (Note 3) 50 pA
TA = -40 to +125°C
, unless other wise noted.) (Note 2)
Operating Supply Voltage Range VDD Inferred from PSRR test 2.7 5.5 V Input Offset Voltage VOS ±8 mV Offset-Voltage Tempco ∆VOS/∆T ±3 µV/°C Input Bias Current TA = -40°C to +85°C 17 (Note 4) IB pA TA = -40°C to +125°C 550 Common-Mode Input Voltage Range VCM Inferred from CMRR test VSS VDD V Common-Mode Rejection Ratio CMRR VSS < VCM < VDD 46 dB Power-Supply Rejection Ratio PSRR VDD = 2.7V to 5.5V 70 dB Output Voltage in Shutdown VOUT(SHDN) VSHDN = 0V, RL = 200Ω (Note 3) 150 mV R Large-Signal Voltage Gain A V L = 2kΩ 76 VOL SS + 0.20V < V dB DD - 0.20V RL = 200Ω 67 RL = 32Ω VDD - VOH 650 TA = +85°C VOL - VSS 650 V Output Voltage Swing V DD - VOH 150 OUT RL = 200Ω mV VOL - VSS 150 V R DD - VOH 20 L = 2kΩ VOL - VSS 20 www.maximintegrated.com Maxim Integrated │ 3
