Оптопары и оптореле Megawin
Datasheet MAX4230, MAX4231, MAX4232, MAX4233, MAX4234 (Maxim) - 6
ПроизводительMaxim
ОписаниеHigh-Output-Drive, 10MHz, 10V/µs, Rail-to-Rail I/O Op Amps with Shutdown in SC70
Страниц / Страница15 / 6 — Typical Operating Characteristics (continued). SUPPLY CURRENT PER …
Формат / Размер файлаPDF / 1.9 Мб
Typical Operating Characteristics (continued). SUPPLY CURRENT PER AMPLIFIER. INPUT OFFSET VOLTAGE. OUTPUT SWING HIGH
Typical Operating Characteristics (continued) SUPPLY CURRENT PER AMPLIFIER INPUT OFFSET VOLTAGE OUTPUT SWING HIGH
39 предложений от 18 поставщиков
MAX4230AXK-T
53 ₽
Эиком
MAX4230AXK+T
от 218 ₽
ТаймЧипс
MAX4230AXK+T
Maxim
TradeElectronics
MAX4230AXKT
Maxim
MAX4230–MAX4234 High-Output-Drive, 10MHz, 10V/μs, Rail-to-Rail I/O Op Amps with Shutdown in SC70
(VDD = 2.7V, VSS = 0V, VCM = VDD/2, VOUT = VDD/2, RL = ∞, connected to VDD/2, VSHDN = VDD, TA = +25°C, unless otherwise noted.)
SUPPLY CURRENT PER AMPLIFIER INPUT OFFSET VOLTAGE OUTPUT SWING HIGH vs. SUPPLY VOLTAGE vs. TEMPERATURE vs. TEMPERATURE
2.0 2 1.8 100 VDD = 5.0V RL = 200Ω 1.6 VDD = 2.7V MAX4230 toc07 MAX4230 toc08 1 MAX4230/34 toc09 1.4 80 1.2 (mV) VDD = 2.7V 60 RL = 200Ω 1.0 (mV) 0 VDD = 5.0V OUT V OS - V 0.8 V DD 40 0.6 SUPPLY CURRENT (mA) -1 0.4 20 0.2 0 -2 0 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 -40 -20 0 20 40 60 80 100 120 -40 -20 0 20 40 60 80 100 120 SUPPLY VOLTAGE (V) TEMPERATURE (°C) TEMPERATURE (°C)
OUTPUT SWING LOW INPUT OFFSET VOLTAGE SUPPLY CURRENT PER AMPLIFIER vs. TEMPERATURE vs. COMMON-MODE VOLTAGE vs. COMMON-MODE VOLTAGE
140 1.0 1.2 120 VDD = 5.0V 0.5 MAX4230/3 toc10 R 1.0 L = 200Ω MAX4230/3 toc11 MAX4230/3 toc12 100 0 (mV) 80 0.8 SS - V -0.5 60 V V OUT DD = 2.7V 0.6 RL = 200Ω -1.0 40 SUPPLY CURRENT (mA) INPUT OFFSET VOLTAGE (mV) 0.4 20 -1.5 VDD = 2.7V 0 -2.0 0.2 -40 -20 0 20 40 60 80 100 120 0 0.5 1.0 1.5 2.0 2.5 0 0.5 1.0 1.5 2.0 2.5 TEMPERATURE (°C) COMMON-MODE VOLTAGE (V) COMMON-MODE VOLTAGE (V)
SUPPLY CURRENT PER AMPLIFIER TOTAL HARMONIC DISTORTION TOTAL HARMONIC DISTORTION PLUS NOISE vs. COMMON-MODE VOLTAGE PLUS NOISE vs. FREQUENCY vs. PEAK-TO-PEAK OUTPUT VOLTAGE
1.4 0.45 10 VOUT = 2VP-P f = 10kHz 0.40 500kHz LOWPASS FILTER VDD = 5V RL = 100k 1.2 0.35 RL = 2k MAX4230/34 toc13 MAX4230/34 toc14 MAX4230/34 toc15 1 RL = 250 1.0 0.30 RL = 25 0.25 0.8 0.20 0.1 THD+N (%) THD+N (%) 0.6 0.15 SUPPLY CURRENT (mA) VDD = 5.0V 0.10 RL = 32 0.4 0.001 0.05 R 0.2 0 L = 10k 0.0001 0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 10 100 1k 10k 100k 4.0 4.2 4.4 4.6 4.8 5.0 COMMON-MODE VOLTAGE (V) FREQUENCY (Hz) PEAK-TO-PEAK OUTPUT VOLTAGE (V) www.maximintegrated.com Maxim Integrated │ 6
