Datasheet AP4405AEN (Asahi Kasei Microdevices) - 9
ПроизводительAsahi Kasei Microdevices
ОписаниеUltra-Low Power Voltage Detector with P and N-Channel MOSFET Switch
Страниц / Страница19 / 9 — 3) Supply voltage(VDD) is powered up and detection voltage(VIN) increases …
Формат / Размер файлаPDF / 972 Кб
3) Supply voltage(VDD) is powered up and detection voltage(VIN) increases separately from VDD (POL = “L”)
AP4405AENпо запросу
[AP4405AEN]
When VIN voltage reaches to the detection voltage (VDETH), the OUT pin outputs VDD voltage.
4) Supply voltage(VDD) is powered up and detection voltage(VIN) decreases separately from VDD (POL = “L”)
When VIN voltage is higher than VDETH, the OUT pin outputs VDD. When VIN goes under the detection voltage (VDETL), the OUT pin outputs VSS. Figure 4. Voltage detection function, VIN is controlled separately from VDD, POL= “L” OUT pin polarity is control ed by POL pin. Table 2 shows MOSSETs output status and OUT pin polarity. Table 2. OUT pin polarity
POL VIN PMOSD NMOSD OUT Note
VIN<V “L” DETH ON OFF L OUT: Positive Polarity VIN≧VDETL OFF ON H VIN<V “H” DETH OFF ON H OUT: Negative Polarity VIN≧VDETL ON OFF L 019001973-E-00 2019/3 - 9 -
