Datasheet AD8018 (Analog Devices) - 2
Описание5 V, Rail-to-Rail, High Output Current, xDSL Line Driver Amplifiers
Страниц / Страница19 / 2 — AD8018–SPECIFICATIONS (@ 25. C, VS = 5 V, RL = 100. , RF = RG = 750. …
ВерсияA
Формат / Размер файлаPDF / 348 Кб
AD8018–SPECIFICATIONS (@ 25. C, VS = 5 V, RL = 100. , RF = RG = 750. unless otherwise noted.) Parameter. Conditions. Min. Typ. Max
AD8018–SPECIFICATIONS (@ 25 C, VS = 5 V, RL = 100 , RF = RG = 750 unless otherwise noted.) Parameter Conditions Min Typ Max
25 предложений от 16 поставщиков
Чип интерфейса, ADSL Driver Dual 8Pin SOIC N T/R
AD8018ARZ-REEL7
138 ₽
ЗУМ-СМД
AD8018ARZ
149 ₽
AD8018ARZ
221 ₽
AD8018ARZ-REEL7
от 306 ₽
, RF = RG = 750
unless otherwise noted.) Parameter Conditions Min Typ Max Unit
DYNAMIC PERFORMANCE –3 dB Bandwidth G = 1, VOUT < 0.4 V p-p, RL = 5 Ω 40 50 MHz G = 1, VOUT < 0.4 V p-p, RL = 100 Ω 100 130 MHz G = 2, VOUT < 0.4 V p-p, RL = 5 Ω 35 40 MHz G = 2, VOUT < 0.4 V p-p, RL = 100 Ω 80 100 MHz 0.1 dB Bandwidth VOUT < 0.4 V p-p, RL = 100 Ω 10 MHz Large Signal Bandwidth VOUT = 4 V p-p, G = +2 80 MHz Slew Rate Noninverting, VOUT = 4 V p-p 300 V/␮s Rise and Fall Time Noninverting, VOUT = 2 V p-p 5.5 ns Settling Time 0.1%, VOUT = 2 V p-p, RL = 100 Ω 25 ns NOISE/HARMONIC PERFORMANCE Distortion, VOUT = 6 V p-p (Differential) Second Harmonic 100 kHz, RL = 10 Ω –89 –94 dBc 500 kHz, RL = 10 Ω –61 –63 dBc Third Harmonic 100 kHz, RL = 10 Ω –86 –89 dBc 500 kHz, RL = 10 Ω –74 –77 dBc MTPR (In-Band) 25 kHz to 138 kHz, RL = 12.5 Ω, PLINE = +13 dBm –70 dBc SFDR (Out-of-Band) 144 kHz to 500 kHz, RL = 12.5 Ω, PLINE = +13 dBm –82 dBc Input Noise Voltage f = 100 kHz 4.5 5 nV√Hz Input Noise Current f = 100 kHz (+Inputs) 1 pA√Hz f = 100 kHz (–Inputs) 10 pA√Hz Crosstalk f = 1 MHz, G = +2 –74 dB DC PERFORMANCE Input Offset Voltage 1 15 mV TMIN to TMAX 17 mV Input Offset Voltage Match 0.1 2.6 mV Transimpedance VOUT = 2 V p-p, RL = 5 Ω 830 2000 kΩ TMIN to TMAX 700 kΩ INPUT CHARACTERISTICS Input Resistance +Input 10 M⍀ –Input 125 Ω Input Capacitance +Input 1 pF Input Bias Current (–) 0.3 8 ␮A TMIN to TMAX 14 ␮A Input Bias Current (–) Match 0.1 5.5 ␮A TMIN to TMAX 8 ␮A Input Bias Current (+) 1 1.5 ␮A TMIN to TMAX 2.5 ␮A Input Bias Current (+) Match 0.1 0.5 ␮A TMIN to TMAX 1 ␮A CMRR VIN 2 V to 4 V 51 54 dB Input CM Voltage Range 1.2 3.8 V OUTPUT CHARACTERISTICS Cap Load 30% Overshoot 1000 pF Output Resistance Frequency = 100 kHz, PWDN1, PWDN0 = 1 0.2 Ω Output Voltage Swing RL = 100 Ω 0.16 to 4.87 V RL = 5 Ω 0.5 to 4.5 V Linear Output Current SFDR < –85 dBc, f = 100 kHz, RL = 10 Ω, Differential 350 400 mA Short-Circuit Current 1000 mA POWER SUPPLY Supply Current/Amp PWDN1 = 1, PWDN0 = 1 9 10 mA TMIN to TMAX 11.4 mA STBY Supply Current/Amp PWDN1 = 0, PWDN0 = 1 or 4.5 5.1 mA PWDN1 = 1, PWDN0 = 0 4.5 5.1 mA SHUTDOWN Supply Current/Amp PWDN1 = 0, PWDN0 = 0 0.3 0.55 mA Operating Range Single Supply 3.3 8 V +Power Supply Rejection Ratio ⌬VS = ⫾1 V 60 66 dB TMIN to TMAX 56 dB –Power Supply Rejection Ratio ⌬VS = ⫾1 V 52 55 dB TMIN to TMAX 50 dB –2– REV. A
